Datasheet LTC2063, LTC2064, LTC2065 (Analog Devices) - 10
Description2µA Supply Current, Low IB, Zero-Drift Operational Amplifiers
Pages / Page32 / 10 — TYPICAL PERFORMANCE CHARACTERISTICS. Maximum Undistorted Output. LTC2065 …
RevisionC
File Format / SizePDF / 3.1 Mb
TYPICAL PERFORMANCE CHARACTERISTICS. Maximum Undistorted Output. LTC2065 Crosstalk vs Frequency. THD vs Frequency
TYPICAL PERFORMANCE CHARACTERISTICS Maximum Undistorted Output LTC2065 Crosstalk vs Frequency THD vs Frequency
LTC2063/LTC2064/LTC2065
TYPICAL PERFORMANCE CHARACTERISTICS Maximum Undistorted Output LTC2065 Crosstalk vs Frequency THD vs Frequency Amplitude vs Frequency
) 0 –20 P-P 6 RL = 10k ADJACENT CHANNELS AV = +1 RL=10kΩ DIAGONAL CHANNELS VS = ±2.5V RL=100kΩ –20 VOUT = ±2V 5 TAGE (V RL=499kΩ –40 –40 TION (dB) 4 –60 ALK (dB) –60 3 TED OUTPUT VOL –80 CROSST 2 –100 –80 R AL HARMONIC DISTOR L=499kΩ R A –120 L=100kΩ V = +1 1 TOT R V L=10kΩ S = ±2.5V THD < –40dB –140 –100 0 100 1k 10k 100k 1M 20 100 500 MAXIMUM UNDISTOR 20 100 1k 2k FREQUENCY (Hz) FREQUENCY (Hz) FREQUENCY (Hz) 2063 G34 2063 G35 2063 G36
Supply Current vs SHDN Pin Supply Current vs Supply Voltage Supply Current vs Temperature Voltage
2.5 2.2 10 VS = 5V 9 125°C 2.0 2.0 8 85°C 1.8 7 V 1.5 S = 5V 25°C 1.6 6 5 –40°C 1.0 1.4 V 4 S = 1.8V 85°C 125°C PER AMPLIFIER (µA) PER AMPLIFIER (µA) 25°C PER AMPLIFIER (µA) 3 I S 1.2 I S I S 0.5 2 1.0 1 –40°C 0 0.8 0 0 0.5 1 1.5 2 2.5 3 3.5 4 4.5 5 5.5 –50 –25 0 25 50 75 100 125 0 0.5 1 1.5 2 2.5 3 3.5 4 4.5 5 VS (V) TEMPERATURE (°C) SHDN PIN VOLTAGE (V) 2063 G37 2063 G38 2063 G39
Supply Current vs SHDN Pin SHDN Pin Pull-Up Current vs SHDN Pin Pull-Up Current vs Voltage SHDN Pin Voltage SHDN Pin Voltage
3.0 20 20 VS = 1.8V VS = 5V 10 VS = 1.8V 10 2.5 0 0 –10 –10 125°C 2.0 –20 –20 85°C –30 –40°C –30 –40°C (nA) 1.5 –40 (nA) –40 25°C 25°C 25°C I SHDN –50 I SHDN –50 –40°C 1.0 –60 PER AMPLIFIER (µA) 85°C –60 85°C I S –70 –70 125°C 0.5 –80 125°C –80 –90 –90 0 –100 –100 0 0.2 0.4 0.6 0.8 1 1.2 1.4 1.6 1.8 –1 0 1 2 3 4 5 6 –1 –0.5 0 0.5 1 1.5 2 SHDN PIN VOLTAGE (V) VSHDN (V) VSHDN (V) 2063 G40 2063 G41 2063 G42 Rev. C 10 For more information www.analog.com Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
