Datasheet ADA4530-1 (Analog Devices) - 2
DescriptionFemtoampere Input Bias Current Electrometer Amplifier
Pages / Page52 / 2 — ADA4530-1. Data Sheet. TABLE OF CONTENTS
File Format / SizePDF / 2.3 Mb
ADA4530-1 Data Sheet TABLE OF CONTENTS
link to page 1 link to page 1 link to page 1 link to page 1 link to page 3 link to page 4 link to page 4 link to page 6 link to page 8 link to page 10 link to page 10 link to page 10 link to page 11 link to page 12 link to page 12 link to page 21 link to page 27 link to page 29 link to page 29 link to page 29 link to page 30 link to page 30 link to page 30 link to page 31 link to page 31 link to page 31 link to page 31 link to page 32 link to page 33 link to page 33 link to page 34 link to page 34 link to page 34 link to page 35 link to page 35 link to page 37 link to page 38 link to page 39 link to page 39 link to page 40 link to page 43 link to page 43 link to page 43 link to page 43 link to page 44 link to page 44 link to page 44 link to page 45 link to page 45 link to page 45 link to page 46 link to page 47 link to page 47 link to page 50 link to page 50 link to page 51 link to page 51 link to page 52 link to page 52
Features .. 1 Input Resistance.. 34 Applications ... 1 Input Offset Voltage ... 34 Pin Connection Diagram .. 1 Insulation Resistance ... 34 General Description ... 1 Guarding .. 35 Revision History ... 3 Dielectric Relaxation .. 35 Specifications ... 4 Humidity Effects ... 37 5 V Nominal Electrical Characteristics ... 4 Contamination .. 38 10 V Nominal Electrical Characteristics ... 6 Cleaning and Handling ... 39 15 V Nominal Electrical Characteristics ... 8 Solder Paste Selection .. 39 Absolute Maximum Ratings .. 10 Current Noise Considerations .. 40 Thermal Resistance .. 10 Layout Guidelines ... 43 ESD Caution .. 10 Physical Implementation of Guarding Techniques.. 43 Pin Configuration and Function Descriptions ... 11 Guard Ring .. 43 Typical Performance Characteristics ... 12 Guard Plane ... 43 Main Amplifier, DC Performance .. 12 Via Fence ... 44 Main Amplifier, AC Performance .. 21 Cables and Connectors .. 44 Guard Amplifier ... 27 Electrostatic Interferance .. 44 Theory of Operation .. 29 Photodiode Interface .. 45 ESD Structure .. 29 DC Error Analysis .. 45 Input Stage ... 29 AC Error Analysis .. 45 Gain Stage .. 30 Noise Analysis ... 46 Output Stage .. 30 Design Recommendations .. 47 Guard Buffer ... 30 Design Example .. 47 Applications Information .. 31 Power Supply Recommendations ... 50 Input Protection .. 31 Power Supply Considerations ... 50 Single-Supply and Rail-to-Rail Output ... 31 Long-Term Drift ... 51 Capacitive Load Stability ... 31 Temperature Hysteresis ... 51 EMI Rejection Ratio ... 32 Outline Dimensions ... 52 High Impedance Measurements ... 33 Ordering Guide .. 52 Input Bias Current .. 33 Rev. B | Page 2 of 52 Document Outline FEATURES APPLICATIONS PIN CONNECTION DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS 5 V NOMINAL ELECTRICAL CHARACTERISTICS 10 V NOMINAL ELECTRICAL CHARACTERISTICS 15 V NOMINAL ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS MAIN AMPLIFIER, DC PERFORMANCE MAIN AMPLIFIER, AC PERFORMANCE GUARD AMPLIFIER THEORY OF OPERATION ESD STRUCTURE INPUT STAGE GAIN STAGE OUTPUT STAGE GUARD BUFFER APPLICATIONS INFORMATION INPUT PROTECTION SINGLE-SUPPLY AND RAIL-TO-RAIL OUTPUT CAPACITIVE LOAD STABILITY EMI REJECTION RATIO HIGH IMPEDANCE MEASUREMENTS INPUT BIAS CURRENT INPUT RESISTANCE INPUT OFFSET VOLTAGE INSULATION RESISTANCE GUARDING DIELECTRIC RELAXATION HUMIDITY EFFECTS CONTAMINATION CLEANING AND HANDLING SOLDER PASTE SELECTION CURRENT NOISE CONSIDERATIONS LAYOUT GUIDELINES PHYSICAL IMPLEMENTATION OF GUARDING TECHNIQUES GUARD RING GUARD PLANE VIA FENCE CABLES AND CONNECTORS ELECTROSTATIC INTERFERANCE PHOTODIODE INTERFACE DC ERROR ANALYSIS AC ERROR ANALYSIS NOISE ANALYSIS DESIGN RECOMMENDATIONS DESIGN EXAMPLE POWER SUPPLY RECOMMENDATIONS POWER SUPPLY CONSIDERATIONS LONG-TERM DRIFT TEMPERATURE HYSTERESIS OUTLINE DIMENSIONS ORDERING GUIDE
