Datasheet ADA4096-2, ADA4096-4 (Analog Devices) - 7
Description30 V, Micropower, Overvoltage Protection, Rail-to-Rail Input/Output Amplifiers
Pages / Page25 / 7 — Data Sheet. ADA4096-2/ADA4096-4. ABSOLUTE MAXIMUM RATINGS Table 5. …
RevisionG
File Format / SizePDF / 640 Kb
Data Sheet. ADA4096-2/ADA4096-4. ABSOLUTE MAXIMUM RATINGS Table 5. THERMAL RESISTANCE. Parameter. Rating
Data Sheet ADA4096-2/ADA4096-4 ABSOLUTE MAXIMUM RATINGS Table 5 THERMAL RESISTANCE Parameter Rating
Data Sheet ADA4096-2/ADA4096-4 ABSOLUTE MAXIMUM RATINGS Table 5. THERMAL RESISTANCE Parameter Rating
θJA is specified for the device soldered on a 4-layer JEDEC Supply Voltage 36 V standard printed circuit board (PCB) with zero airflow. The Input Voltage exposed pad is soldered to the application board. Operating Condition −V ≤ VIN ≤ +V Overvoltage Condition1 (−V) − 32 V ≤ V
Table 6. Thermal Resistance
IN ≤ (+V) + 32 V Differential Input Voltage2 ±V
Package Type θJA θJC Unit
SY Input Current ±5 mA 8-Lead MSOP (RM-8) 142 45 °C/W Output Short-Circuit Duration to Indefinite 8-Lead LFCSP (CP-8-10) 76 43 °C/W GND 14-Lead TSSOP (RU-14) 112 35 °C/W Storage Temperature Range −65°C to +150°C 16-Lead LFCSP (CP-16-22) 75 12 °C/W Operating Temperature Range −40°C to +125°C Junction Temperature Range −65°C to +150°C Lead Temperature (Soldering, 300°C
ESD CAUTION
60 seconds) 1 Performance not guaranteed during overvoltage conditions. 2 Limit the input current to ±5 mA. Stresses at or above those listed under Absolute Maximum Ratings may cause permanent damage to the product. This is a stress rating only; functional operation of the product at these or any other conditions above those indicated in the operational section of this specification is not implied. Operation beyond the maximum operating conditions for extended periods may affect product reliability. Rev. G | Page 7 of 25 Document Outline Features Applications Pin Connection Diagrams General Description Revision History Specifications Electrical Specifications, VSY = ±1.5 V Electrical Specifications, VSY = ±5 V Electrical Specifications, VSY = ±15 V Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics ±1.5 V Characteristics ±5 V Characteristics ±15 V Characteristics Comparative Voltage and Variable Voltage Graphs Theory of Operation Input Stage Phase Inversion Input Overvoltage Protection Comparator Operation Outline Dimensions Ordering Guide Automotive Products
