Datasheet ADA4096-2, ADA4096-4 (Analog Devices) - 9
Description | 30 V, Micropower, Overvoltage Protection, Rail-to-Rail Input/Output Amplifiers |
Pages / Page | 25 / 9 — Data Sheet. ADA4096-2/ADA4096-4. OUTA. 14 OUTD. –INA 1. 12 –IND. –INA. 13 … |
Revision | G |
File Format / Size | PDF / 640 Kb |
Data Sheet. ADA4096-2/ADA4096-4. OUTA. 14 OUTD. –INA 1. 12 –IND. –INA. 13 –IND. +INA 2. ADA4096-4. 11 +IND. +INA. ADA4096-4 12 +IND. TOP. V+ 3. 10 V–
Data Sheet ADA4096-2/ADA4096-4 A D C T T I U U CI N O O N 6 5 4 3 1 1 1 1 OUTA 1 14 OUTD –INA 1 12 –IND –INA 2 13 –IND +INA 2 ADA4096-4 11 +IND +INA 3 ADA4096-4 12 +IND TOP V+ 3 10 V– VIEW V+ 4 TOP VIEW 11 V– +INB 4 9 +INC (Not to Scale) +INB 5 10 +INC 8 –INB 6 7 9 –INC 5 6 B B C C
101
N T T N OUTB 7 8 OUTC I U I – U – O O
09241- 03
NOTES
1
1. NIC = NOT INTERNALLY CONNECTED.
9241-
2. CONNECT THE EXPOSED PAD TO V–.
0 Figure 6. 14-Lead TSSOP (RU-14), ADA4096-4 Figure 7. 16-Lead LFCSP (CP-16-22), ADA4096-4
Table 8. Pin Function Descriptions, ADA4096-4 Pin No.1 14-Lead TSSOP 16-Lead LFCSP Mnemonic Description
1 15 OUTA Output Channel A. 2 1 −INA Negative Input Channel A. 3 2 +INA Positive Input Channel A. 4 3 V+ Positive Supply Voltage. 5 4 +INB Positive Input Channel B. 6 5 −INB Negative Input Channel B. 7 6 OUTB Output Channel B. 8 7 OUTC Output Channel C. 9 8 −INC Negative Input Channel C. 10 9 +INC Positive Input Channel C. 11 10 V− Negative Supply Voltage. 12 11 +IND Positive Input Channel D. 13 12 −IND Negative Input Channel D. 14 14 OUTD Output Channel D. N/A 13 NIC No Internal Connection. N/A 16 NIC No Internal Connection. N/A EP2 EPAD Exposed Pad.2 For the ADA4096-4 (16-lead LFCSP only), connect the exposed pad to V−. 1 N/A means not applicable. 2 The exposed pad is not shown in the pin configuration diagram. Rev. G | Page 9 of 25 Document Outline Features Applications Pin Connection Diagrams General Description Revision History Specifications Electrical Specifications, VSY = ±1.5 V Electrical Specifications, VSY = ±5 V Electrical Specifications, VSY = ±15 V Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics ±1.5 V Characteristics ±5 V Characteristics ±15 V Characteristics Comparative Voltage and Variable Voltage Graphs Theory of Operation Input Stage Phase Inversion Input Overvoltage Protection Comparator Operation Outline Dimensions Ordering Guide Automotive Products
