Datasheet ADA4691-2, ADA4691-4, ADA4692-2, ADA4692-4 (Analog Devices) - 7
DescriptionLow Power, 3.6 MHz, Low Noise, Rail-to-Rail Output, Operational Amplifiers
Pages / Page19 / 7 — Data Sheet. ADA4691-2/ADA4691-4/ADA4692-2/ADA4692-4. PIN CONFIGURATIONS. …
RevisionE
File Format / SizePDF / 805 Kb
Data Sheet. ADA4691-2/ADA4691-4/ADA4692-2/ADA4692-4. PIN CONFIGURATIONS. BALL A1. CORNER. OUT A 1. 8 V+. OUT B. OUT A. –IN A 2. ADA4692-2
Data Sheet ADA4691-2/ADA4691-4/ADA4692-2/ADA4692-4 PIN CONFIGURATIONS BALL A1 CORNER OUT A 1 8 V+ OUT B OUT A –IN A 2 ADA4692-2
Data Sheet ADA4691-2/ADA4691-4/ADA4692-2/ADA4692-4 PIN CONFIGURATIONS BALL A1 CORNER OUT A 1 8 V+ OUT B V+ OUT A –IN A 2 ADA4692-2 7 OUT B TOP VIEW A1 A2 A3 +IN A 3 (Not to Scale) 6 –IN B
16 -0
–IN B SD A/B –IN A V– 4 5 +IN B
950 07
B1 B2 B3
Figure 6. 8-Lead, 2 mm × 2 mm LFCSP (CP-8-6)
+IN B V– +IN A C1 C2 C3 OUT A 1 8 V+ ADA4691-2 –IN 2 ADA4692-2 7 OUT B TOP VIEW
58 -0
+IN 3 TOP VIEW 6 –IN B (BALL SIDE DOWN)
50
(Not to Scale)
001
Not to Scale
079
V– 5 +IN B 4
50- 079 Figure 3. 9-Ball Wafer Level Chip Scale WLCSP (CB-9-3) Figure 7. 8-Lead SOIC_N (R-8)
A TU + O V OUT A 1 14 OUT D 01 9 –IN A 2 13 –IN D +IN A 3 ADA4692-4 12 +IN D –IN A 1 8 OUT B ADA4691-2 TOP VI V E I W E V+ 4 11 V– (Not (N to t Sc S a c le) +IN A 2 7 –IN B TOP VIEW (Not to Scale) +IN B 5 10 +IN C V– 3 6 +IN B –IN B 6 9 –IN C
9 05
4 5
2
OUT B 7 8 OUT C
00
A B
950- 0- 07
D D
95
S S
07 Figure 4. 10-Lead, 2 mm × 2 mm LFCSP (CP-10-11) Figure 8. 14-Lead TSSOP (RU-14)
A A D T T D NI U U N O O I– 61 51 41 31 +IN A 1 12 +IN D V+ 2 11 V– ADA4691-4 +IN B 3 10 +IN C –IN B 4 9 –IN C 5 6 7 8 B B / D/ C T A C T U D U O D S S O TOP VIEW (Not to Scale)
0
NOTES
06 0-
1. IT IS RECOMMENDED THAT THE EXPOSED
95
PAD BE CONNCECTED TO V–.
07 Figure 5. 16-Lead, 3 mm × 3 mm LFCSP (CP-16-22) Rev. E | Page 7 of 19 Document Outline Features Applications General Description Revision History Specifications Electrical Characteristics—2.7 V Operation Electrical Characteristics—5 V Operation Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configurations Typical Performance Characteristics Shutdown Operation Input Pin Characteristics Input Threshold Outline Dimensions Ordering Guide
