Datasheet AD8565, AD8566, AD8567 (Analog Devices) - 4
Description16 V Rail-to-Rail Operational Amplifiers
Pages / Page13 / 4 — AD8565/AD8566/AD8567. Data Sheet. ABSOLUTE MAXIMUM RATINGS Table 2. …
RevisionH
File Format / SizePDF / 335 Kb
AD8565/AD8566/AD8567. Data Sheet. ABSOLUTE MAXIMUM RATINGS Table 2. THERMAL RESISTANCE. Parameter. Rating
AD8565/AD8566/AD8567 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 2 THERMAL RESISTANCE Parameter Rating
AD8565/AD8566/AD8567 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 2. THERMAL RESISTANCE Parameter Rating
θJA is specified for worst-case conditions, that is, for a device Supply Voltage (V soldered onto a circuit board for surface-mount packages. S) 18 V Input Voltage −0.5 V to VS + 0.5 V
Table 3. Thermal Resistance
Differential Input Voltage VS
Package Type θJA θJC Unit
Storage Temperature Range −65°C to +150°C 5-Lead SC70 (KS-5) 376 126 °C/W Operating Temperature Range −40°C to +85°C 8-Lead MSOP (RM-8) 210 45 °C/W Junction Temperature Range −65°C to +150°C 14-Lead TSSOP (RU-14) 180 35 °C/W Lead Temperature (Soldering, 60 sec) 300°C 16-Lead LFCSP (CP-16-23) 381 301 °C/W Stresses at or above those listed under Absolute Maximum 1 DAP is soldered down to the printed circuit board (PCB). Ratings may cause permanent damage to the product. This is a stress rating only; functional operation of the product at these
ESD CAUTION
or any other conditions above those indicated in the operational section of this specification is not implied. Operation beyond the maximum operating conditions for extended periods may affect product reliability. Rev. H | Page 4 of 13 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONFIGURATIONS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION INPUT OVERVOLTAGE PROTECTION OUTPUT PHASE REVERSAL POWER DISSIPATION THERMAL PAD—AD8567 TOTAL HARMONIC DISTORTION + NOISE (THD + N) SHORT-CIRCUIT OUTPUT CONDITIONS LCD PANEL APPLICATIONS OUTLINE DIMENSIONS ORDERING GUIDE
