Datasheet AD8565, AD8566, AD8567 (Analog Devices) - 5
Description | 16 V Rail-to-Rail Operational Amplifiers |
Pages / Page | 13 / 5 — Data Sheet. AD8565/AD8566/AD8567. TYPICAL PERFORMANCE CHARACTERISTICS. … |
Revision | H |
File Format / Size | PDF / 335 Kb |
Data Sheet. AD8565/AD8566/AD8567. TYPICAL PERFORMANCE CHARACTERISTICS. 1000. VCM = VS/2. 4.5V ≤ VS ≤ 16V. TA = 25°C. –0.25. ) V. √Hz. m (
Data Sheet AD8565/AD8566/AD8567 TYPICAL PERFORMANCE CHARACTERISTICS 0 1000 VCM = VS/2 4.5V ≤ VS ≤ 16V TA = 25°C –0.25 ) ) V √Hz m ( V/ n GE –0.50 Y ( 100 T LTA V SI O S = 16V EN V T –0.75 E E D VS = 4.5V IS O OFFS –1.00 N T E 10 U G P A T IN L –1.25 O V –1.50 1 –40 25 85
005 08 9-
10 100 1k 10k
0
TEMPERATURE (°C)
90 09- 01
FREQUENCY (Hz)
019 Figure 5. Input Offset Voltage vs. Temperature Figure 8. Voltage Noise Density vs. Frequency
10 1.0 4.5V ≤ V VO = VS/2 S ≤ 16V ) T A A = 25°C V = +1 A) TA = 25°C √Hz 0.8 (m A/ p R IE Y ( IF IT L S P 0.6 N /AM 1 E DE NT IS 0.4 NO T URRE N C E Y L RR P 0.2 CU UP S 0.1 0 10 100 1k 10k
-006
0 2 4 6 8 10 12 14 16 18
009 9-
FREQUENCY (Hz)
909
SUPPLY VOLTAGE (V)
190 01 0 Figure 6. Current Noise Figure 9. Supply Current/Amplifier vs. Supply Voltage
0.80 VS = 16V V R CM = VS/2 L = 10kΩ C ) L = 100pF A 0.75 AV = +1 (m T V A = 25°C S = 16V IER ) IF 0.70 IV /D PL V M /A T 50m 0.65 ( E EN R M R TI U C 0.60 Y L PP VS = 4.5V SU 0.55
07 0
0.50
10 9-
–40 25 85
0
FREQUENCY (1µs/DIV)
90 9- 01
TEMPERATURE (°C)
90 01 Figure 7. Small Signal Transient Response Figure 10. Supply Current/Amplifier vs. Temperature Rev. H | Page 5 of 13 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONFIGURATIONS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION INPUT OVERVOLTAGE PROTECTION OUTPUT PHASE REVERSAL POWER DISSIPATION THERMAL PAD—AD8567 TOTAL HARMONIC DISTORTION + NOISE (THD + N) SHORT-CIRCUIT OUTPUT CONDITIONS LCD PANEL APPLICATIONS OUTLINE DIMENSIONS ORDERING GUIDE
