Datasheet AD8565, AD8566, AD8567 (Analog Devices) - 8
Description16 V Rail-to-Rail Operational Amplifiers
Pages / Page13 / 8 — AD8565/AD8566/AD8567. Data Sheet. n ( T. z) H. S = 4.5V. H (. CUR T. IDT. …
RevisionH
File Format / SizePDF / 335 Kb
AD8565/AD8566/AD8567. Data Sheet. n ( T. z) H. S = 4.5V. H (. CUR T. IDT. S = 16V. W 3. VS = 16V. INP. AV = +1. L = x. TA = 25°C. –40. TEMPERATURE (°C)
AD8565/AD8566/AD8567 Data Sheet n ( T z) H S = 4.5V H ( CUR T IDT S = 16V W 3 VS = 16V INP AV = +1 L = x TA = 25°C –40 TEMPERATURE (°C)
AD8565/AD8566/AD8567 Data Sheet 5 7 4 6 A) 3 n ( T 2 5 N z) H RE 1 M V 4 S = 4.5V H ( CUR T 0 IDT E V S S = 16V W 3 F D F –1 AN O B UT –2 2 VS = 16V INP –3 AV = +1 1 R –4 L = x TA = 25°C –5 0
3 26
–40 25 85 0 2 4 6 8 10 12 14 16
02 -0 9- 909
TEMPERATURE (°C) COMMON-MODE VOLTAGE (V)
190 01 0 Figure 23. Input Offset Current vs. Temperature Figure 26. Frequency vs. Common-Mode Voltage (VS = 16 V)
0 6 V V CM = VS/2 S = 5V A –50 V = +1 5 RL = 10kΩ T A) VS = 16V A = 25°C n ( –100 ) T 4 N Hz M RRE –150 H ( V CU S = 4.5V 3 IDT W AS –200 D BI AN UT B 2 P –250 IN 1 –300 –350 0
4
–40 25 85
02
0 1 2 3 4 5
027 9- 9-
TEMPERATURE (°C)
90
90 01 01 Figure 24. Input Bias Current vs. Temperature Figure 27. Frequency vs. Common-Mode Voltage (VS = 5 V)
–20 –40 –60 B) d –80 K ( TAL –100 4.5V S S O R –120 C 16V –140 –160 –180
5
50 100 1k 10k 60k
02 09-
FREQUENCY (Hz)
19 0 Figure 25. Channel A vs. Channel B Crosstalk Rev. H | Page 8 of 13 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONFIGURATIONS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION INPUT OVERVOLTAGE PROTECTION OUTPUT PHASE REVERSAL POWER DISSIPATION THERMAL PAD—AD8567 TOTAL HARMONIC DISTORTION + NOISE (THD + N) SHORT-CIRCUIT OUTPUT CONDITIONS LCD PANEL APPLICATIONS OUTLINE DIMENSIONS ORDERING GUIDE
