Datasheet AD8005 (Analog Devices) - 8
Description270 MHz, 400 μA Current Feedback Amplifier
Pages / Page16 / 8 — AD8005. Data Sheet. 12.5. VS = +5V OR ±5V. –10. G = +2 RL = 1kΩ. –15. z) …
RevisionB
File Format / SizePDF / 378 Kb
AD8005. Data Sheet. 12.5. VS = +5V OR ±5V. –10. G = +2 RL = 1kΩ. –15. z) H. 10.0. –20. E (nV. –25. 7.5. OIS. –30. RR (. –35. 5.0. OLTA. –40. T V PU. –45. 2.5. –50. –55
AD8005 Data Sheet 12.5 VS = +5V OR ±5V –10 G = +2 RL = 1kΩ –15 z) H 10.0 –20 E (nV –25 7.5 OIS –30 RR ( –35 5.0 OLTA –40 T V PU –45 2.5 –50 –55
AD8005 Data Sheet –5 12.5 VS = +5V OR ±5V –10 G = +2 RL = 1kΩ –15 z) H 10.0 /√ –20 E (nV –25 7.5 B) OIS d N –30 RR ( GE CM –35 5.0 OLTA –40 T V PU –45 IN 2.5 –50 –55 0
021
0.03 0.1 1 10 100
018
10 100 1k 10k 100k 1M 10M FREQUENCY (MHz) FREQUENCY (Hz)
12146- 12146- Figure 18. CMRR vs. Frequency; VS = +5 V or ±5 V Figure 21. Noise vs. Frequency; VS = +5 V or ±5 V
62.5 VS = +5V OR ±5V G = +2 RL = 1kΩ ) 100 ) 50.0 √Hz E (Ω C N TA ISE (pA/ 37.5 NO ESIS NT T R 10 U 25.0 VS = +5V TP CURRE OU UT 12.5 V INP INVERTING CURRENT S = ±5V NONINVERTING CURRENT 1 0 0.03 0.1 1 10 100 500
019
022
FREQUENCY (MHz)
12146-
FREQUENCY (Hz)
12146- Figure 19. Output Resistance vs. Frequency; VS = ±5 V and +5 V Figure 22. Noise vs. Frequency; VS = +5 V or ±5 V
10 VS = +5V OR ±5V –PSRR 0 G = +2 RL = 1kΩ V –10 100 OUT 90 –20 +PSRR VIN B) d –30 RR ( V S –40 S = ±5V P G = +6 R –50 L = 1kΩ –60 10 0% –70 1V 2V 150ns
023
–80 0.03 0.1 1 10 100 500
020 12146-
FREQUENCY (MHz)
12146- Figure 20. PSRR vs. Frequency; VS = +5 V or ±5 V Figure 23. ±Overdrive Recovery, VS = ±5 V, VIN = 2 V Step Rev. B | Page 8 of 16 Document Outline Features Applications General Description Functional Block Diagrams Table of Contents Revision History Specifications ±5 V Supplies +5 V Supply Absolute Maximum Ratings Thermal Resistance Maximum Power Dissipation ESD Caution Typical Performance Characteristics Applications Driving Capicative Loads Single-Supply Level Shifter Single-Ended-to-Differential Conversion Layout Considerations Increasing Feedback Resistors Outline Dimensions Ordering Guide
