Datasheet OP220 (Analog Devices) - 2
DescriptionDual Micropower Operational Amplifier - Obsolete
Pages / Page12 / 2 — OP220–SPECIFICATIONS. ELECTRICAL CHARACTERISTICS (@ VS =. 2.5 V to. 15 V, …
OP220–SPECIFICATIONS. ELECTRICAL CHARACTERISTICS (@ VS =. 2.5 V to. 15 V, TA = 25. C, unless otherwise noted.). OP220A/E OP220F
OP220–SPECIFICATIONS ELECTRICAL CHARACTERISTICS (@ VS = 2.5 V to 15 V, TA = 25 C, unless otherwise noted.) OP220A/E OP220F
2.5 V to
15 V, TA = 25
C, unless otherwise noted.) OP220A/E OP220F OP220C/G Parameter Symbol Conditions Min Typ Max Min Typ Max Min Typ Max Unit
Input Offset Voltage VOS VS = ± 2.5 V to ± 15 V 120 150 250 300 500 750 mV Input Offset Current IOS VCM = 0 0.15 1.5 0.2 2 0.2 3.5 nA Input Bias Current IB VCM = 0 12 20 13 25 14 30 nA Input Voltage Range IVR V+ = 5 V, V– = 0 V 0/3.5 0/3.5 0/3.5 V VS = ± 15 V –15/+13.5 –15/+13.5 –15/+13.5 V Common-Mode CMRR V+ = 5 V, V– = 0 V 90 100 85 90 75 85 dB Rejection Ratio 0 V £ VCM £ 3.5 V VS = ± 15 V 95 100 90 95 80 90 dB –15 V £ VCM £ +13.5 V Power Supply PSRR VS = ± 2.5 V to ± 15 V, 3 10 10 32 32 100 mV/V Rejection Ratio V– = 0 V, V+ = 5 V to 30 V 6 18 18 57 57 180 mV/V Large-Signal AVO V+ = 5 V, V– = 0 V, 500 1,000 500 800 300 500 V/mV Voltage Gain RL = 100 kW, 1 V £ VO £ 3.5 V VS = ± 15 V, RL = 25 kW 1,000 2,000 1,000 2,000 800 1,600 V/mV VO = ± 10 V Output Voltage VO V+ = 5 V, V– = 0 V 0.7/4 0.7/4 0.8/4 V Swing RL = 10 kW VS = ± 15 V, RL = 25 kW ±14 ±14 ±14 V Slew Rate* SR RL =25 kW 0.05 0.05 0.05 V/ms Bandwidth BW AVCL = 1, RL =25 kW 200 200 200 kHz Supply Current ISY VS = ±2.5 V, No Load 100 115 115 125 125 135 mA (Both Amplifiers) VS = ±15 V, No Load 140 170 150 190 205 220 mA *Sample tested.
(V ELECTRICAL CHARACTERISTICS s =
2.5 V to
15 V, –55
C
TA
+125
C for OP220A/C, –25
C
TA
+85
C for OP220E/F, –40
C
TA
+85
C for OP220G unless otherwise noted.) OP220A/E OP220F OP220C/G Parameter Symbol Conditions Min Typ Max Min Typ Max Min Typ Max Unit
Input Offset Voltage TCVOS VS = ± 15 V 0.75 1.5 1.2 2 2 3 mV/∞C Drift* Input Offset Voltage VOS 200 300 400 500 1,000 1,300 mV Input Offset Current IOS VCM = 0 0.5 2 0.6 2.5 0.6 5 nA Input Bias Current IB VCM = 0 12 25 13 30 14 40 nA Input Voltage Range IVR V+ = 5 V, V– = 0 V 0/3.2 0/3.2 0/3.2 V VS = ± 15 V –15/+13.2 –15/+13.2 –15/+13.2 V
OBSOLETE
Common-Mode CMRR V+ = 5 V, V– = 0 V 86 90 80 85 70 80 dB Rejection Ratio 0 V £ VCM £ 3.2 V VS = ± 15 V 90 95 85 90 75 85 dB –15 V £ VCM £ +13.2 V Power Supply PSRR VS = ± 2.5 V to ± 15 V, 6 18 18 57 57 180 mV/V Rejection Ratio V– = 0 V, V+ = 5 V to 30 V 10 32 32 100 100 320 mV/V Large-Signal AVO VS = ± 15 V, RL = 50 kW 500 1,000 500 800 400 500 V/mV Voltage Gain VO = ± 10 V Output Voltage VO V+ = 5 V, V– = 0 V 0.9/3.8 0.9/3.8 1.0/3.8 V Swing RL = 20 kW VS = ± 15 V, RL = 50 kW ±13.6 ±13.6 ±13.6 V Supply Current ISY VS = ±2.5 V, No Load 135 170 155 185 170 210 mA (Both Amplifiers) VS = ±15 V, No Load 190 250 200 280 275 330 mA *Sample tested. –2– REV. A Document Outline FEATURES GENERAL DESCRIPTION PIN CONFIGURATIONS SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS DIE CHARACTERISTICS ORDERING GUIDE WAFER TEST LIMITS Typical Performance Characteristics INSTRUMENTATION AMPLIFIER APPLICATIONS OF THE OP220 Two Op Amp Configuration THREE OP AMP CONFIGURATION OUTLINE DIMENSIONS Revision History
