Datasheet OP220 (Analog Devices) - 6
DescriptionDual Micropower Operational Amplifier - Obsolete
Pages / Page12 / 6 — OP220. 120. 160. TA = 25. A = 25. S = 15V. 140. VS = 15V. 100. GAIN. …
OP220. 120. 160. TA = 25. A = 25. S = 15V. 140. VS = 15V. 100. GAIN. PHASE. CMRR – dB. OPEN-LOOP GAIN – dB. PHASE SHIFT – Degrees. 135. m = 53. 180. 0.01
OP220 120 160 TA = 25 A = 25 S = 15V 140 VS = 15V 100 GAIN PHASE CMRR – dB OPEN-LOOP GAIN – dB PHASE SHIFT – Degrees 135 m = 53 180 0.01
OP220 120 160 0 TA = 25
C T V A = 25
C S = 15V 140 VS = 15V 100 120 45 80 GAIN 100 PHASE 60 80 90 CMRR – dB 60 40 OPEN-LOOP GAIN – dB PHASE SHIFT – Degrees 40 135
m = 53
20 20 0 0 180 0.01 0.1 1 10 100 1k 0.01 0.1 1 10 100 1k 10k 100k 1M FREQUENCY – Hz FREQUENCY – Hz
TPC 7. CMRR vs. Frequency TPC 10. Open-Loop Voltage Gain and Phase vs. Frequency
130 36 T T A = 25
C A = 25
C 120 32 V V S = 15V S = 15V V 110 28 100 24 +PSRR 90 20 80 16 PSRR – dB 70 O-PEAK AMPLITUDE – 12 –PSRR 60 8 PEAK-T 50 4 40 0 1 10 100 1k 10k 100k 100 1k 10k 100k 1M FREQUENCY – Hz FREQUENCY – Hz
TPC 8. PSRR vs. Frequency TPC 11. Maximum Output Swing vs. Frequency
17 0.09 TA = 25
C 0.08 15 V VS = 15V 0.07 VS = 15V GE – 0.06 A sec T
VS = 5V OL 10 V/ V 0.05 TE – 0.04 OBSOLETE 0.03 5 SLEW RA PEAK OUTPUT VS = 5V 0.02 0.01 0 0 1 10 100 –75 –50 –25 0 25 50 75 100 125 150 LOAD RESISTANCE – k
TEMERATURE –
C
TPC 9. Maximum Output Voltage vs. Load Resistance TPC 12. Slew Rate vs. Temperature –6– REV. A Document Outline FEATURES GENERAL DESCRIPTION PIN CONFIGURATIONS SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS DIE CHARACTERISTICS ORDERING GUIDE WAFER TEST LIMITS Typical Performance Characteristics INSTRUMENTATION AMPLIFIER APPLICATIONS OF THE OP220 Two Op Amp Configuration THREE OP AMP CONFIGURATION OUTLINE DIMENSIONS Revision History
