Datasheet KSZ8993 (Microchip) - 9
ManufacturerMicrochip
Description3-Port 10/100 Integrated Switch with PHY and Frame Buffer
Pages / Page35 / 9 — Pin Number. Pin Name. Type(Note 1). Port. Pin Function. Note 1. I/O …
File Format / SizePDF / 231 Kb
Pin Number. Pin Name. Type(Note 1). Port. Pin Function. Note 1. I/O Grouping. Group Name. Description
Pin Number Pin Name Type(Note 1) Port Pin Function Note 1 I/O Grouping Group Name Description
KS8993 Micrel
116 P1_PP I 1 Port 1 receive port based priority classification 117 P1_TAGINS I 1 Port 1 tag insertion enable 118 P2_TAGINS I 2 Port 2 tag insertion enable 119 P3_TAGINS I 3 Port 3 tag insertion enable 120 P3_TAGRM I 3 Port 3 tag removal enable 121 P2_TAGRM I 2 Port 2 tag removal enable 122 P1_TAGRM I 1 Port 1 tag removal enable 123 VDD_RCV[1] Pwr 1 2.5V for clock recovery circuitry 124 GND_RCV[1] GND 1 Ground for clock recovery circuitry 125 X2 O Connect to crystal input 126 X1 I Crystal or clock input 127 FXSD[1] I 1 Fiber signal detect 128 AOUT O Factory test output
Note 1.
Pwr = power supply GND = ground I = input O = output I/O = bi-directional
PHY Physical Interface MII Media Independant Interface SNI Serial Network Interface IND LED Indicators UP Unmanaged Programmable CTRL Control and Miscellaneous TEST Test (Factory) PWR Power and Ground May 2005 9 KS8993
