Datasheet HMC862A (Analog Devices) - 9
Description0.1 GHz to 24 GHz, Low Noise, Programmable Divider
Pages / Page15 / 9 — Data Sheet. HMC862A. DIVIDE BY 4. R (. +85°C. VCC = 5.25V. +25°C. VCC = …
RevisionA
File Format / SizePDF / 483 Kb
Data Sheet. HMC862A. DIVIDE BY 4. R (. +85°C. VCC = 5.25V. +25°C. VCC = 5.00V. –40°C. VCC = 4.75V. SINE WAVE INPUT FREQUENCY (GHz). MAX PIN
Data Sheet HMC862A DIVIDE BY 4 R ( +85°C VCC = 5.25V +25°C VCC = 5.00V –40°C VCC = 4.75V SINE WAVE INPUT FREQUENCY (GHz) MAX PIN
Data Sheet HMC862A DIVIDE BY 4 6 6 5 5 4 ) 4 ) Bm Bm d 3 d 3 R ( R ( E E W 2 W O 2 O P P UT 1 UT P 1 P UT UT O O 0 0 +85°C VCC = 5.25V –1 +25°C –1 VCC = 5.00V –40°C VCC = 4.75V –2 –2 0 2 4 6 8 10 12 14 16 18 20 22 24
33 34 0
0 9- 9-
59
59 13 13 Figure 15. Output Power vs. Sine Wave Input Frequency for Various Figure 18. Output Power vs. Sine Wave Input Frequency for Various VCC Temperatures, PIN = 0 dBm Voltages, PIN = 0 dBm
15 0 MAX PIN 10 –10 5 ) Bm Bm) +85°C d –20 d 0 +25°C R ( R ( –40°C E E W W –5 O –30 O P C P T NI U –10 O P –40 IN –15 HARM FEEDTHROUGH MIN PIN –50 SECOND HARMONIC –20 THIRD HARMONIC –25 –60 0 2 4 6 8 10 12 14 16 18 20 22 24
27 0
0 1 2 3 4 5 6
36 0 9- 9-
59 59 13
OUTPUT FREQUENCY (GHz)
13 Figure 16. Allowable Range of Input Power vs. Sine Wave Input Frequency Figure 19. Output Harmonics, PIN = 0 dBm, TA = 25°C for Various Temperatures
–115 –115 SQUARE 100MHz PIN = +10dBm –120 SINE 100MHz (5dBm) –120 PIN = +5dBm SINE 18GHz PIN = 0dBm –125 SINE 12GHz –125 PIN = –5dBm z) SINE 6GHz z) PIN = –10dBm c/H –130 c/H –130 B B d ( –135 E –135 IS ISE (d O –140 O –140 N N E SE –145 –145 A HAS PH –150 B P –150 S S SSB –155 –155 –160 –160 –165 –165
7 38
100 1k 10k 100k 1M
03
100 1k 10k 100k 1M
0 9-
OFFSET FREQUENCY (Hz) OFFSET FREQUENCY (Hz)
359 13599- 1 Figure 17. SSB Phase Noise vs. Offset Frequency for Various Input Figure 20. SSB Phase Noise vs. Offset Frequency for Various Input Power (PIN) Frequencies, PIN = 0 dBm, TA = 25°C Levels, fIN = 12 GHz Sine Wave, TA = 25°C Rev. A | Page 9 of 15 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS RF SPECIFICATIONS DC SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS DIVIDE BY 1 DIVIDE BY 2 DIVIDE BY 4 DIVIDE BY 8 CURRENT CONSUMPTION (ICC) THEORY OF OPERATION INPUT INTERFACE OUTPUT INTERFACE APPLICATIONS INFORMATION EVALUATION PRINTED CIRCUIT BOARD (PCB) EVALUATION BOARD OVERVIEW OUTLINE DIMENSIONS ORDERING GUIDE
