Datasheet HMC983LP5E (Analog Devices) - 4
DescriptionDC - 7 GHz Fractional-N Divider and Frequency Sweeper
Pages / Page32 / 4 — HMC983LP5E. DC - 7 GHz FRACTIONAL-N DIVIDER. AND FREQUENCY SWEEPER. …
HMC983LP5E. DC - 7 GHz FRACTIONAL-N DIVIDER. AND FREQUENCY SWEEPER. Figure 7. Time Domain 124 MHz Output,
HMC983LP5E DC - 7 GHz FRACTIONAL-N DIVIDER AND FREQUENCY SWEEPER Figure 7 Time Domain 124 MHz Output,
HMC983LP5E
v02.0112
DC - 7 GHz FRACTIONAL-N DIVIDER AND FREQUENCY SWEEPER Figure 7. Time Domain 124 MHz Output, Figure 8. Time Domain 66 MHz Output, 6.5 GHz Input
[5]
6.5 GHz Input
[5] 5.5 5.5 divCkPFDp Pin Output divCkPFDp Pin Output t (V) (V) E 5 E 5 M AG AG T T L L s VO VO T T PU PU T 4.5 T U 4.5 U s - O O r divCkPFDn Pin Output divCkPFDn Pin Output o 4 4 t 0 5 10 15 20 25 30 0 10 20 30 40 50 c TIME (ns) TIME (ns) e t e
Figure 9. Time Domain 61 MHz Output, Figure 10. Time Domain 66 MHz Output, 6.5 GHz Input
[5]
6.5 GHz Input
[5] 5.5 5.5 s & D divCkPFDp Pin Output divCkPFDp Pin Output r (V) (V) E E e 5 5 AG AG T T L L iD VO VO T T PU PU iv T 4.5 T U 4.5 U O O y D divCkPFDn Pin Output divCkPFDn Pin Output c 4 4 0 10 20 30 40 50 0 10 20 30 40 50 n TIME (ns) TIME (ns) e u q
Figure 11. 10 MHz Output Swing vs Figure 12. 50 MHz Output Swing vs Buffer
e
Buffer Current
[6]
Current
[6] r 0.9 0.9 F p) 0.85 pp) 0.85 0.8 ING (V 0.8 W 0.75 0.75 UT S 0.7 0.7 D OUTP 0.65 0.65 NDE -ENDED OUTPUT SWING (Vp -E E 0.6 -40 C E 0.6 -40 C +27 C +27 C INGL SINGL 0.55 +85 C S 0.55 +85 C 0.5 0.5 12 13 14 15 16 17 18 12 13 14 15 16 17 18 OUTPUT BUFFER CURRENT (mA) OUTPUT BUFFER CURRENT (mA) [4] Measured with 50 Ω impedance per line, integer Mode, 15 mA output Buffer current (reg 0Fh[4:2]) selected [5] Measured with 50 Ω impedance per line, integer Mode, 15 mA output Buffer current (reg 0Fh[4:2]) selected Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd ho e ne r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o tniltie n .c e ao t m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com
4
Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
