Datasheet HMC983LP5E (Analog Devices) - 10
DescriptionDC - 7 GHz Fractional-N Divider and Frequency Sweeper
Pages / Page32 / 10 — HMC983LP5E. DC - 7 GHz FRACTIONAL-N DIVIDER. AND FREQUENCY SWEEPER. …
HMC983LP5E. DC - 7 GHz FRACTIONAL-N DIVIDER. AND FREQUENCY SWEEPER. Evaluation PCB. Table 4. Evaluation Order Information
HMC983LP5E DC - 7 GHz FRACTIONAL-N DIVIDER AND FREQUENCY SWEEPER Evaluation PCB Table 4 Evaluation Order Information
HMC983LP5E
v02.0112
t M s s - r o t c e t e s & D r e iD iv y D c n e u q e r F the circuit board used in the application should use rF circuit design techniques. signal lines should have 50 ohms impedance while the package ground leads and exposed paddle should be connected directly to the ground plane similar to that shown unless mentioned otherwise. A sufficient number of via holes should be used to connect the top and bottom ground planes. the evaluation circuit board shown is available from Hittite upon request.
item contents Part number Dc - 7 GHz FrActionAL-n DiviDer and HMc984LP4e PLL chipset evaluation PcB usB interface Board e K i t 0 1 - evaluation Kit 6’ usB A Male to usB B Female cable Dc -7 GHz FrActionAL-n DiviDer cD roM (contains user Manual, evaluation PcB schematic, evaluation software) Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd ho e ne r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o tniltie n .c e ao t m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com
10
Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
