Datasheet HMC361S8G, 361S8GE (Analog Devices)
DescriptionSMT GaAs HBT MMIC Divide-by-2, DC - 10 GHz
Pages / Page6 / 1 — HMC361S8G/361S8GE. SMT GaAs HBT MMIC. DIVIDE-BY-2, DC - 10 GHz. Typical …
File Format / SizePDF / 524 Kb
HMC361S8G/361S8GE. SMT GaAs HBT MMIC. DIVIDE-BY-2, DC - 10 GHz. Typical Applications. Features. Functional Diagram
Datasheet HMC361S8G, 361S8GE Analog Devices
HMC361S8G/361S8GE
v08.1119
SMT GaAs HBT MMIC DIVIDE-BY-2, DC - 10 GHz Typical Applications Features
4 Prescaler for DC to X Band PLL Applications: Ultra Low SSB Phase Noise: -148 dBc/Hz 4 • Satel ite Communication Systems Wide Bandwidth T • Fiber Optic Output Power: 3 dBm T M • Point-to-Point and Point-to-Multi-Point Radios Single DC Supply: +5V M • VSAT S8G SMT Package S - S S - S R R O
O T T C The HMC361S8G & HMC361S8GE are low noise C E Divide-by-2 Static Dividers with InGaP GaAs HBT E T technology in 8 lead surface mount plastic packages. T E This device operates from DC (with a square wave E input) to 10 GHz input frequency with a single +5V DC supply. The low additive SSB phase noise of -148 S & D dBc/Hz at 100 kHz offset helps the user maintain good S & D R system noise performance. R E E ID ID IV IV Y D Y D C C N N E E U U Q
Electrical Specifications, T = +25° C, 50 Ohm System, Vcc= 5V A
Q E Parameter Conditions Min. Typ. Max. Units E R Maximum Input Frequency 10 11 GHz R F Minimum Input Frequency Sine Wave Input. [1] 0.2 0.5 GHz F Input Power Range Fin = 1 to 8 GHz -15 +10 dBm Fin = 8 to 10 GHz -10 +2 dBm Output Power Fin = 6 GHz 0 3 dBm Fin = 10 GHz -6 dBm Reverse Leakage Both RF Outputs Terminated 45 dB SSB Phase Noise (100 kHz offset) Pin = 0 dBm, Fin = 6 GHz -148 dBc/Hz Output Transition Time Pin = 0 dBm, Fout = 882 MHz 100 ps Supply Current (Icc) 83 mA 1. Divider will operate down to DC for square-wave input signal. I F nf o or r p mati roic n e fu , d rnis e h leiv d e b ry y , a Analn o d t g D o p evic leac s i e o s bel rid ev e e rs d t : A o b n e a a lco c g D urat e e a v n ic d re elsi, I abl n e c . H , O owe n vee T r, n e o chn F o o lo r p g ri y W ce a , d y el, P ive.O ry . B , anox 9 d t 10 o pl 6 a , N c o e orrw de o r o s d, M : Anal A 0 o 2 g D 0 e 6 vi 2 c - e 9 s 10 , I 6 nc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106
4 - 1
rights of third parties that may result from its use. SpP e h ci o fic n ate io: 78 ns su1 b - j 3 ec 2 t t 9- o c 4 h 7 an 0 g 0 • O e withourd t n e otir o ce n . N li o ne at www.analog.com license is granted by implication or otherwise under an A y pa p te p n li t o ca r p t atio enn S t rig u ht pp s o o f A rnta: P lo h g D o e n vi e ce : 1 s. -80 P 0 ho -A ne NA : 7 L 81 O -3 G 2 - 9-D4700 • Order online at www.analog.com Trademarks and registered trademarks are the property of their respective owners. Application Support: Phone: 1-800-ANALOG-D
