Datasheet AD74412R (Analog Devices) - 8
DescriptionQuad-Channel, Software Configurable Input/Output
Pages / Page66 / 8 — AD74412R. Data Sheet. CURRENT INPUT EXTERNALLY POWERED. Table 4. …
AD74412R. Data Sheet. CURRENT INPUT EXTERNALLY POWERED. Table 4. Parameter. Min. Typ. Max. Unit. Test Conditions/Comments
AD74412R Data Sheet CURRENT INPUT EXTERNALLY POWERED Table 4 Parameter Min Typ Max Unit Test Conditions/Comments
link to page 12
AVDD = 14 V to 26.4 V, AGND = DGND = 0 V, REFIN = 2.5 V (REFOUT tied to REFIN), DVCC = 2.7 V to 5.5 V, IOVDD = 1.7 V to 5.5 V, and all specifications at TA=−40°C to +85°C, unless otherwise noted. CLOAD = 68 nF per recommended configuration. AGND − 0.5 V < I/OP_x screw terminal voltage < AVDD − 0.2 V, and RSENSE = 100 Ω, 0.1%, 10 ppm/°C.
Table 4. Parameter Min Typ Max Unit Test Conditions/Comments
CURRENT INPUT Input Resolution 16 Bits Input Range 0 25 mA Sensed across the external 100 Ω resistor Short-Circuit Current Limit 25 35 mA Nonprogrammable ACCURACY TUE1 −0.5 +0.5 %FSR Internal reference, 0.16% contribution from RSENSE −0.36 +0.36 %FSR External reference, 0.16% contribution from RSENSE TUE at 25°C −0.34 +0.34 %FSR Internal reference −0.2 +0.2 %FSR External reference TUE Drift vs. Time1, 2 700 ppm FSR Internal reference, drift after 1000 hours, TA = 85°C 600 ppm FSR External reference, drift after 1000 hours, TA = 85°C INL −5 +2 +5 LSB Gain Error 2000 ppm FSR Offset Error ±2 LSB OTHER INPUT SPECIFICATIONS DC PSRR2 150 nA/V Input Impedance 200 Ω Including 100 Ω RSENSE Compliance 6.3 V Minimum voltage required at the I/OP_x screw terminal to sink 25 mA 1 RSENSE accuracy directly impacts the TUE and gain error. 2 Guaranteed by design and characterization; not production tested. Rev. A | Page 8 of 66 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION COMPANION PRODUCTS PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY FUNCTIONAL BLOCK DIAGRAM SPECIFICATIONS VOLTAGE OUTPUT CURRENT OUTPUT VOLTAGE INPUT CURRENT INPUT EXTERNALLY POWERED CURRENT INPUT LOOP POWERED RTD MEASUREMENT DIGITAL INPUT LOGIC DIGITAL INPUT LOOP POWERED ADC SPECIFICATIONS GENERAL SPECIFICATIONS TIMING CHARACTERISTICS SPI Timing Specifications Timing Diagrams ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS VOLTAGE OUTPUT CURRENT OUTPUT REFERENCE ADC SUPPLIES THEORY OF OPERATION ROBUST ARCHITECTURE SERIAL INTERFACE DAC ARCHITECTURE ADC OVERVIEW REFERENCE Reference Noise Charge Pump POWER-ON STATE OF THE AD74412R DEVICE FUNCTIONS High Impedance Interpreting ADC Data Voltage Output Mode Voltage Output Short-Circuit Protection Interpretin ADC Data Current Output Mode Current Output Open Circuit Detection Interpreting ADC Data Voltage Input Mode Selectable 200 kΩ to GND Interpreting ADC Data Current Input, Externally Powered Mode Short-Circuit Protection Interpreting ADC Data Current Input, Loop Powered Mode Short-Circuit Protection Interpreting ADC Data Resistance Measurement (External 2-Wire RTD) Interpreting ADC Data Digital Input Logic Interpreting ADC Data Digital Input Current Sink Digital Input Threshold Setting Debounce Function Debounce Mode 0 (Default) Debounce Mode 1 Digital Input Inverter DIGITAL INPUT, LOOP POWERED MODE Interpreting ADC Data GETTING STARTED USING CHANNEL FUNCTIONS Switching Channel Functions ADC FUNCTIONALITY ADC Conversion Rates ADC_RDYB Functionality ADC Output Data Format ADC Noise DIAGNOSTICS DACs LDAC Function Clear Code Function Digital Linear Slew Rate Control DRIVING INDUCTIVE LOADS RESET FUNCTION THERMAL ALERT AND THERMAL RESET FAULTS AND ALERTS Channel Faults POWER SUPPLY MONITORS GPO_x PINS SPI INTERFACE AND DIAGNOSTICS SPI CRC SPI Interface SCLK Count Feature Readback Mode Streaming Mode Auto Readback BOARD DESIGN AND LAYOUT CONSIDERATIONS APPLICATIONS INFORMATION REGISTER MAP NOP REGISTER FUNCTION SETUP REGISTER PER CHANNEL ADC CONFIGURATION REGISTER PER CHANNEL DIGITAL INPUT CONFIGURATION REGISTER PER CHANNEL GPO PARALLEL DATA REGISTER GPO CONFIGURATION REGISTER PER CHANNEL OUTPUT CONFIGURATION REGISTER PER CHANNEL DAC CODE REGISTER PER CHANNEL DAC CLEAR CODE REGISTER PER CHANNEL DAC ACTIVE CODE REGISTER PER CHANNEL DIGITAL INPUT THRESHOLD REGISTER ADC CONVERSION CONTROL REGISTER DIAGNOSTICS SELECT REGISTER DIGITAL OUTPUT LEVEL REGISTER ADC CONVERSION RESULTS REGISTER PER CHANNEL DIAGNOSTIC RESULTS REGISTERS PER DIAGNOSTIC CHANNEL ALERT STATUS REGISTER LIVE STATUS REGISTER ALERT MASK REGISTER READBACK SELECT REGISTER 80 SPS ADC CONVERSION CONTROL REGISTER THERMAL RESET ENABLE REGISTER COMMAND REGISTER SCRATCH OR SPARE REGISTER SILICON REVISION REGISTER OUTLINE DIMENSIONS ORDERING GUIDE
