Datasheet BCR431U (Infineon) - 10
ManufacturerInfineon
DescriptionLow Voltage Drop LED Driver IC
Pages / Page11 / 10 — BCR431U Low Voltage Drop LED Driver IC. References. Figure 8. Tape & …
Revision01_00
File Format / SizePDF / 299 Kb
BCR431U Low Voltage Drop LED Driver IC. References. Figure 8. Tape & Reel PG-SOT23-6. Revision history Document. Date of
BCR431U Low Voltage Drop LED Driver IC References Figure 8 Tape & Reel PG-SOT23-6 Revision history Document Date of
4 4 0.25 8 .2 3 P IN 1 INDEX MARKING 3.3 1.55 ALL DIMENSIONS ARE IN UNITS MM THE DRAWING IS IN COMPLIANCE WITH ISO 128 & P ROJ ECTION METHOD 1 [ ]
Figure 8 Tape & Reel PG-SOT23-6 6 References Revision history Document Date of Description of changes version release
1.0 2020-03-03 First data sheet release Datasheet 10 1.0 2020-03-03 Document Outline Features Advantages with respect to discrete solutions Potential Applications Description Table of contents 1 Application circuit 2 Pin configuration 3 Functional description 4 Electrical characteristics and parameters 5 Package dimensions 6 References Revision history Disclaimer
