Datasheet LTM8025 (Analog Devices)
Description36V, 3A Step-Down µModule Regulator
Pages / Page22 / 1 — FEATURES. DESCRIPTION. Complete Step-Down Switch Mode Power Supply. Wide …
RevisionD
File Format / SizePDF / 974 Kb
FEATURES. DESCRIPTION. Complete Step-Down Switch Mode Power Supply. Wide Input Voltage Range: 3.6V to 36V
Datasheet LTM8025 Analog Devices, Revision: D
LTM8025 36V, 3A Step-Down µModule Regulator
FEATURES DESCRIPTION
n
The LTM®8025 is a 36VIN, 3A step-down µModule® n
(micromodule) converter. Included in the package are n
Up to 3A Output Current
the switching controller, power switches, inductor and n
Parallelable for Increased Output Current
all support components. Operating over an input voltage n
0.8V to 24V Output Voltage
range of 3.6V to 36V, the LTM8025 supports an output n
Selectable Switching Frequency: 200kHz to 2.4MHz
voltage range of 0.8V to 24V and a switching frequency n Current Mode Control range of 200kHz to 2.4MHz, each set by a single resistor. n SnPb or RoHS Compliant Finish Only the bulk input and output filter capacitors are needed n Programmable Soft-Start to finish the design. n 9mm × 15mm × 4.32mm LGA and 9mm × 15mm × The LTM8025 is packaged in a thermally enhanced, com- 4.92mm BGA Packages pact (9mm × 15mm) and low profile over-molded land
grid array (LGA) and ball grid array (BGA) packages suit- able for automated assembly by standard surface mount n equipment. The LTM8025 is available with SnPb (BGA) Automotive Battery Regulation n or RoHS compliant terminal finish. Power for Portable Products n Distributed Supply Regulation All registered trademarks and trademarks are the property of their respective owners. n Industrial Supplies n Wall Transformer Regulation
TYPICAL APPLICATION Efficiency
100 VIN = 24V VIN* V V OUT IN VOUT 90 22V TO 36V 12V AT 3A RUN/SS AUX 4.7µF 80 LTM8025 BIAS SHARE PGOOD 22µF 70 RT ADJ EFFICIENCY(%) 60 SYNC GND 47.5k 34.8k 50 *RUNNING VOLTAGE RANGE. PLEASE REFER TO APPLICATIONS INFORMATION SECTION FOR START-UP DETAILS 8025 TA01a 40 0 500 1000 1500 2000 2500 3000 OUTPUT CURRENT (mA) 8025 TA01b Rev. D Document Feedback For more information www.analog.com 1 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Operation Applications Information Package Description Revision History Package Photography Typical Application Related Parts
