Datasheet LT4356-1, LT4356-2 (Analog Devices) - 3
DescriptionSurge Stopper
Pages / Page26 / 3 — ORDER INFORMATION. TUBE. TAPE AND REEL. PART MARKING*. PACKAGE …
RevisionC
File Format / SizePDF / 480 Kb
ORDER INFORMATION. TUBE. TAPE AND REEL. PART MARKING*. PACKAGE DESCRIPTION. TEMPERATURE RANGE
ORDER INFORMATION TUBE TAPE AND REEL PART MARKING* PACKAGE DESCRIPTION TEMPERATURE RANGE
LT4356-1/LT4356-2
LT4356CDE-1#PBF LT4356CDE-1#TRPBF 43561 12-Lead (4mm × 3mm) Plastic DFN 0°C to 70°C LT4356IDE-1#PBF LT4356IDE-1#TRPBF 43561 12-Lead (4mm × 3mm) Plastic DFN –40°C to 85°C LT4356HDE-1#PBF LT4356HDE-1#TRPBF 43561 12-Lead (4mm × 3mm) Plastic DFN –40°C to 125°C LT4356CDE-2#PBF LT4356CDE-2#TRPBF 43562 12-Lead (4mm × 3mm) Plastic DFN 0°C to 70°C LT4356IDE-2#PBF LT4356IDE-2#TRPBF 43562 12-Lead (4mm × 3mm) Plastic DFN –40°C to 85°C LT4356HDE-2#PBF LT4356HDE-2#TRPBF 43562 12-Lead (4mm × 3mm) Plastic DFN –40°C to 125°C LT4356CMS-1#PBF LT4356CMS-1#TRPBF LTCNS 10-Lead Plastic MSOP 0°C to 70°C LT4356IMS-1#PBF LT4356IMS-1#TRPBF LTCNS 10-Lead Plastic MSOP –40°C to 85°C LT4356HMS-1#PBF LT4356HMS-1#TRPBF LTCNS 10-Lead Plastic MSOP –40°C to 125°C LT4356CS-1#PBF LT4356CS-1#TRPBF LT4356S-1 16-Lead Plastic SO 0°C to 70°C LT4356IS-1#PBF LT4356IS-1#TRPBF LT4356S-1 16-Lead Plastic SO –40°C to 85°C LT4356HS-1#PBF LT4356HS-1#TRPBF LT4356S-1 16-Lead Plastic SO –40°C to 125°C LT4356CS-2#PBF LT4356CS-2#TRPBF LT4356S-2 16-Lead Plastic SO 0°C to 70°C LT4356IS-2#PBF LT4356IS-2#TRPBF LT4356S-2 16-Lead Plastic SO –40°C to 85°C LT4356HS-2#PBF LT4356HS-2#TRPBF LT4356S-2 16-Lead Plastic SO –40°C to 125°C LT4356CDE-1 LT4356CDE-1#TR 43561 12-Lead (4mm × 3mm) Plastic DFN 0°C to 70°C LT4356IDE-1 LT4356IDE-1#TR 43561 12-Lead (4mm × 3mm) Plastic DFN –40°C to 85°C LT4356HDE-1 LT4356HDE-1#TR 43561 12-Lead (4mm × 3mm) Plastic DFN –40°C to 125°C LT4356CDE-2 LT4356CDE-2#TR 43562 12-Lead (4mm × 3mm) Plastic DFN 0°C to 70°C LT4356IDE-2 LT4356IDE-2#TR 43562 12-Lead (4mm × 3mm) Plastic DFN –40°C to 85°C LT4356HDE-2 LT4356HDE-2#TR 43562 12-Lead (4mm × 3mm) Plastic DFN –40°C to 125°C LT4356CMS-1 LT4356CMS-1#TR LTCNS 10-Lead Plastic MSOP 0°C to 70°C LT4356IMS-1 LT4356IMS-1#TR LTCNS 10-Lead Plastic MSOP –40°C to 85°C LT4356HMS-1 LT4356HMS-1#TR LTCNS 10-Lead Plastic MSOP –40°C to 125°C LT4356CS-1 LT4356CS-1#TR LT4356S-1 16-Lead Plastic SO 0°C to 70°C LT4356IS-1 LT4356CS-1#TR LT4356S-1 16-Lead Plastic SO –40°C to 85°C LT4356HS-1 LT4356HS-1#TR LT4356S-1 16-Lead Plastic SO –40°C to 125°C LT4356CS-2 LT4356CS-2#TR LT4356S-2 16-Lead Plastic SO 0°C to 70°C LT4356IS-2 LT4356IS-2#TR LT4356S-2 16-Lead Plastic SO –40°C to 85°C LT4356HS-2 LT4356HS-2#TR LT4356S-2 16-Lead Plastic SO –40°C to 125°C Contact the factory for parts specified with wider operating temperature ranges. *The temperature grade is identified by a label on the shipping container. Tape and reel specifications. Some packages are available in 500 unit reels through designated sales channels with #TRMPBF suffix. Rev. C For more information www.analog.com 3 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Operation Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
