T3902 Bottom Port PDM Low‐Power Multi‐Mode Microphone With High AOP Mode GENERAL DESCRIPTION APPLICATIONS The T3902 is a low‐power, low‐noise digital MEMS Smartphones microphone in a small package. The T3902 consists of a Microphone Arrays Tablets MEMS microphone element and an impedance converter Cameras amplifier followed by a fourth‐order Σ‐Δ modulator. The pulse Bluetooth Headsets density modulated (PDM) interface allows two microphones Notebook PCs to be time multiplexed on a data line using a single clock. Security and Surveillance The T3902 has multiple modes of operation: High FEATURES Performance, Low Power (AlwaysOn), Standard and Sleep. SPEC LOW‐POWER STANDARD HIGH The T3902 has low power and high SNR in all operational MODE MODE PERFORMANCE modes. It has 126 dB SPL AOP in High Performance mode, and MODE 120 dB SPL AOP in Standard and Low‐Power modes. Sensitivity −26 dB FS ±1 dB −26 dB FS ±1 dB −32 dB FS ±1 dB SNR 63 dBA 64.5 dBA 64 dBA The T3902 is available in a small 3.5 × 2.65 × 0.98 mm Current 185 µA 430 µA 650 µA surface‐mount package. It is reflow solder compatible with AOP 120 dB SPL 120 dB SPL 126 dB SPL no sensitivity degradation. Clock 400 – 800 kHz 1.0 – 3.3 MHz 4.1 – 4.8 MHz 3.5 × 2.65 × 0.98 mm surface‐mount package Low power: 185 µA in Low‐Power Mode Extended frequency response from 36 Hz to >20 kHz Sleep Mode: 12 µA High power supply rejection (PSR): −97 dB FS Fourth‐order Σ‐Δ modulator Digital pulse density modulation (PDM) output Compatible with Sn/Pb and Pb‐free solder processes RoHS/WEEE compliant FUNCTIONAL BLOCK DIAGRAM ORDERING INFORMATION
PART TEMP RANGE PACKAGING MMICT3902‐00‐012 −40°C to +85°C 13” Tape and Reel EV_T3902‐FX — InvenSense Inc. InvenSense, Inc. reserves the right to change the detail 1745 Technology Drive, San Jose, CA 95110 U.S.A Document Number: DS‐000357 specifications as may be required to permit +1(408) 988–7339 Revision: 1.0 improvements in the design of its products. www.invensense.com Rev Date: 4/15/2020
