Datasheet PI4IOE5V9554 (Diodes) - 4
Manufacturer | Diodes |
Description | 2 8-bit I C-Bus and SMBus I/O Port with Interrupt |
Pages / Page | 17 / 4 — PI4IOE5V9554/9554A. Symbol. Parameter. Conditions. Min. Typ. Max. Unit. … |
File Format / Size | PDF / 887 Kb |
PI4IOE5V9554/9554A. Symbol. Parameter. Conditions. Min. Typ. Max. Unit. I/Os. Interrupt. Select Inputs A0, A1, A2. Note:. www.diodes.com
PI4IOE5V9554/9554A Symbol Parameter Conditions Min. Typ. Max. Unit I/Os
VIL Low Level Input Voltage — -0.5 — +0.81 V VIH High Level Input Voltage — +1.8 — 5.5 V VCC = 2.3V; VOL = 0.5V[2] 8 10 — mA VCC = 2.3V; VOL = 0.7V[2] 10 13 — mA VCC = 3.0V; V I OL = 0.5V[2] 8 14 — mA OL Low Level Output Current VCC = 3.0V; VOL = 0.7V[2] 10 19 — mA VCC = 4.5V; VOL = 0.5V[2] 8 17 — mA VCC = 4.5V; VOL = 0.7V2] 10 24 — mA IOH = -8mA; VCC = 2.3V[3] 1.8 — — V IOH = -10mA; VCC = 2.3V[3] 1.7 — — V I V OH =-8mA; VCC = 3.0V[3] 2.6 — — V OH High Level Output Current IOH = -10mA; VCC = 3.0V[3] 2.5 — — V IOH = -8mA; VCC = 4.5V[3] 4.1 — — V IOH = -10mA; VCC = 4.5V[3] 4.0 — — V ILI Low Level Input Leakage Current VCC = 3.6V; VI = VCC -1 — 1 μA IL Leakage Current VCC = 5.5V; VI = GND — — -100 μA Ci Input Capacitance — — 3.7 10 pF Co Output Capacitance — — 3.7 10 pF
Interrupt
INT IOL Low Level Output Current VOL = 0.4V 3 — — mA
VIL Low Level Input Voltage — -0.5 — +0.81 V VIH High Level Input Voltage — +1.8 — 5.5 V IL Input Leakage Current — -1 — 1 μA
Note:
1. VCC must be lowered to 0.2V for at least 20µs in order to reset part. 2. Each I/O must be limited to a maximum current of 25mA and the device must be limited to a maximum current of 100mA. 3. The total current sourced by all I/Os must be limited to 85mA. PI4IOE5V9554/ PI4IOE5V9554A
www.diodes.com
November 2019 Document Number DS40769 Rev 3 - 2 4 © Diodes Incorporated Document Outline — Supply Voltage fSCL = 400kHz Supply Current — VI = GND fSCL = 0kHz I/O = inputs Standby Current VI = VCC fSCL = 0kHz I/O = inputs Power-on Reset Voltage[1]
