Datasheet AP61100, AP61102 (Diodes)
Manufacturer | Diodes |
Description | 2.3V To 5.5V Input, 1A Low Iq Synchronous Buck Converter |
Pages / Page | 22 / 1 — AP61100/AP61102. 2.3V TO 5.5V INPUT, 1A LOW IQ SYNCHRONOUS BUCK … |
File Format / Size | PDF / 1.6 Mb |
AP61100/AP61102. 2.3V TO 5.5V INPUT, 1A LOW IQ SYNCHRONOUS BUCK CONVERTER. Description. Pin Assignments. (Top View). FB 1. 6 OUT
AP61100/AP61102 2.3V TO 5.5V INPUT, 1A LOW IQ SYNCHRONOUS BUCK CONVERTER Description Pin Assignments
The AP61100/AP61102 is a 1A, synchronous buck converter with a
(Top View)
wide input voltage range of 2.3V to 5.5V. The device fully integrates a 110mΩ high-side power MOSFET and an 80mΩ low-side power MOSFET to provide high-efficiency step-down DC-DC conversion.
FB 1 6 OUT FB 1 6 PG
The AP61100/AP61102 device is easily used by minimizing the
GND 2 AP61100 5 EN GND 2 AP61102 5 EN
external component count due to its adoption of Constant On-Time (COT) control to achieve fast transient response, easy loop
VIN 3 4 SW VIN 3 4 SW
stabilization, and low output voltage ripple. The device is available in a SOT563 package.
SOT563 Features Applications
VIN: 2.3V to 5.5V 5V Distributed Power Bus Supplies Output Voltage (VOUT): 0.6V to 3.6V White Goods and Small Home Appliances 1A Continuous Output Current FPGA, DSP, and ASIC Supplies 0.6V ± 2% Reference Voltage Network Video Cameras 15μA Low Quiescent Current (Pulse Frequency Modulation) Wireless Routers 2.2MHz Switching Frequency (VIN = 5V, VOUT = 1.8V) Consumer Electronics Up to 89% Efficiency at 5mA Light Load General Purpose Point of Load Programmable Operation Mode Through EN Pulse Frequency Modulation Pulse Width Modulation Regardless of Output Load Power-Good Indicator AP61102 Protection Circuitry Undervoltage Lockout (UVLO) VIN Overvoltage Protection (OVP) Peak Current Limit Valley Current Limit Thermal Shutdown
Totally Lead-Free & Fully RoHS Compliant (Notes 1 & 2) Halogen and Antimony Free. “Green” Device (Note 3) For automotive applications requiring specific change control (i.e. parts qualified to AEC-Q100/101/200, PPAP capable, and manufactured in IATF 16949 certified facilities), please contact us or your local Diodes representative. https://www.diodes.com/quality/product-definitions/ An Automotive-Compliant Part is Available Under Separate Datasheet (AP61100Q/AP61102Q)
Notes: 1. No purposely added lead. Fully EU Directive 2002/95/EC (RoHS), 2011/65/EU (RoHS 2) & 2015/863/EU (RoHS 3) compliant. 2. See https://www.diodes.com/quality/lead-free/ for more information about Diodes Incorporated’s definitions of Halogen- and Antimony-free, "Green" and Lead-free. 3. Halogen- and Antimony-free "Green” products are defined as those which contain <900ppm bromine, <900ppm chlorine (<1500ppm total Br + Cl) and <1000ppm antimony compounds. AP61100/AP61102 1 of 22 June 2020 Document number: DS42004 Rev. 4 - 2
www.diodes.com
© Diodes Incorporated
