HMC1030LP5E v03.1113 DUAL RMS POWER DETECTORDC - 3.9 GHzFeatures • Crest Factor (Peak-to-Average Power Ratio) • Supports Controller Mode Measurement • ± 1 dB Detection Accuracy to 3.9 GHz • Envelope-to-Average Power Ratio Measurement • Input Dynamic Range -55 dBm to +15 dBm • Dual channel and channel difference • +5V Operation from -40° C to +85° C output ports • Excellent Temperature Stability • Excellent Channel Matching and Channel Isolation • Integrated Temperature Sensor 11 • RF Signal Wave Shape & Crest Factor • Power-Down Mode Independent • 32 Lead 5x5mm SMT Package: 25mm² Typical Applications T • Log -> Root - Mean - Square (RMS) • Received Signal Strength Indication (RSSI) M Conversion • Transmitter Signal Strength Indication (TSSI) S • Transmitter Power Control • Dual Channel wireless infrastructure radio - • Receiver Automatic Gain Control • Antenna VSWR Monitor RS O T Functional Diagram C TE E RMS & Envelope Response to WCDMA 4 Carrier with -20dBm RF Input @ 0.9 GHz D 2.17 80 R ETOUT 1.86 60 RMSOUT WE 1.55 40 O ) RF Input (mV) V 20 P 1.24 ( S M 0.93 0 , R T E 0.62 -20 V 0.31 -40 0 -60 RF Input -0.31 -80 0 200 400 600 800 1000 Time (ns) Info F rmoatr p ion rfiurcne is , d hed ebly ivAe n r al y a og D n evd t ice o p s is bla eli c eve o ed t rd o b e e ras: H ccuratite tiatne M d reli iac bl reo . w Ho av wev e C er, n o o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rporation, 20 Alpha Road, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 11 - 1 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd hone e r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o t niltie n .c e ao t m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 p o lica rti a o p n S p u s p @ po h rt itt : P ite ho . n c e om : 1-800-ANALOG-D
