link to page 10 LTC5582 ELECTRICAL CHARACTERISTICSThe l denotes the specifications which apply over the full operatingtemperature range, otherwise specifications are at TC = 25°C. VCC = 3.3V, EN = 3.3V. Test circuit is shown in Figure 1. (Notes 2 and 3).PARAMETERCONDITIONSMINTYPMAXUNITS 2nd Order Harmonic Distortion At RF Input; CW Input; PIN = 0dBm 67 dBc 3rd Order Harmonic Distortion At RF Input; CW Input; PIN = 0dBm 62 dBc fRF = 880MHz RF Input Power Range CW; Single-Ended, 50Ω –57 to 2 dBm Linear Dynamic Range (Note 6) ±1dB Linearity Error 59 dB Output Slope 29.3 mV/dB Logarithmic Intercept (Notes 4, 6) –86.4 dBm Output Variation vs Temperature Normalized to Output at 25°C, Pin = –50dBm to 0dBm l ±0.5 dB Deviation from CW Response 11dB Peak to Average Ratio (3-Carrier CDMA2K) 0.1 dB 12dB Peak to Average Ratio (4-Carrier WCDMA) 0.1 dB 2nd Order Harmonic Distortion At RF Input; CW Input; PIN = 0dBm 69 dBc 3rd Order Harmonic Distortion At RF Input; CW Input; PIN = 0dBm 59 dBc fRF = 2140MHz RF Input Power Range CW; Single-Ended, 50Ω –56 to 1 dBm Linear Dynamic Range (Note 6) ±1dB Linearity Error 50 57 dB Output Slope 26 29.5 33 mV/dB Logarithmic Intercept (Notes 4, 6) –98 –85 –72 dBm Output Variation vs Temperature Normalized to Output at 25°C, Pin = –47dBm to 0dBm l ±0.5 dB Deviation from CW Response 11 dB Peak to Average Ratio (3-Carrier CDMA2K) 0.1 dB 12dB Peak to Average Ratio (4-Carrier WCDMA) 0.1 dB fRF = 2700MHz RF Input Power Range CW; Single-Ended, 50Ω –55 to 1 dBm Linear Dynamic Range (Note 6) ±1dB Linearity Error 56 dB Output Slope 29.8 mV/dB Logarithmic Intercept (Notes 4, 6) –83.8 dBm Output Variation vs Temperature Normalized to Output at 25°C, Pin = –47dBm to 0dBm l ±0.5 dB Deviation from CW Response 12dB Peak to Average Ratio (WiMAX OFDM) 0.2 dB fRF = 3800MHz RF Input Power Range CW; Single-Ended, 50Ω –51 to 2 dBm Linear Dynamic Range (Note 6) ±1dB Linearity Error 53 dB Output Slope 30.3 mV/dB Logarithmic Intercept (Notes 4, 6) –81 dBm Output Variation vs Temperature Normalized to Output at 25°C, Pin = –51dBm to 2dBm l ±1 dB Deviation from CW Response 12dB Peak to Average Ratio (WiMAX OFDM) 0.2 dB fRF = 5800MHz RF Input Power Range CW; Single-Ended, 50Ω –46 to 3 dBm Linear Dynamic Range (Note 6) ±1dB Linearity Error 49 dB Output Slope 30.9 mV/dB Logarithmic Intercept (Notes 4, 6) –74.7 dBm Output Variation vs Temperature Normalized to Output at 25°C, Pin = –46dBm to 2dBm l ±1 dB Deviation from CW Response 12dB Peak to Average Ratio (WiMAX OFDM) 0.2 dB Rev. B For more information www.analog.com 3 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Order Information Electrical Characteristics Pin Configuration Typical Performance Characteristics Pin Functions Test Circuits Applications Information Package Description Revision History Typical Application Related Parts
