Datasheet ADL5505 (Analog Devices) - 7
Description450 MHz TO 6000 MHz TruPwr Detector
Pages / Page20 / 7 — ADL5505. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. VPOS. VRMS. RFIN. …
RevisionA
ADL5505. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. VPOS. VRMS. RFIN. COMM. TOP VIEW. (BALL SIDE DOWN). Not to Scale
ADL5505 PIN CONFIGURATION AND FUNCTION DESCRIPTIONS VPOS VRMS RFIN COMM TOP VIEW (BALL SIDE DOWN) Not to Scale
ADL5505 PIN CONFIGURATION AND FUNCTION DESCRIPTIONS VPOS 1 4 VRMS RFIN 2 3 COMM ADL5505 TOP VIEW
003
05799- Figure 3. Pin Configuration
Table 3. Pin Function Descriptions Pin No. Mnemonic Description
1 VPOS Supply Voltage. The operational range is 2.5 V to 3.3 V. 2 RFIN Signal Input. This pin is internally ac-coupled after internal termination resistance. The nominal input impedance is 500 3 COMM Device Ground. 4 VRMS RMS Output. This pin is a rail-to-rail voltage output with limited current drive capability. The output has an internal 100 Ω series resistance. High resistive loads and low capacitance loads are recommended to preserve output swing and allow fast response. Rev. A | Page 7 of 20 Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Circuit Description RMS Circuit Description and Filtering Filtering Output Buffer Applications Information Basic Connections RF Input Interfacing Resistive Tap RF Input Multiple RF Inputs Linearity Output Swing Output Offset Output Drive Capability and Buffering Selecting the Output Low-Pass Filter Power Consumption Device Calibration and Error Calculation Calibration for Improved Accuracy Drift Over a Reduced Temperature Range Device Handling Land Pattern and Soldering Information Evaluation Board Outline Dimensions Ordering Guide
