Datasheet HMC909LP4E (Analog Devices) - 5
DescriptionRMS Power Detector Single-Ended SMT, DC - 5.8 GHz
Pages / Page21 / 5 — HMC909LP4E. RMS POWER DETECTOR. SINGLE-ENDED, DC - 5.8 GHz. RMSOUT & …
File Format / SizePDF / 3.3 Mb
HMC909LP4E. RMS POWER DETECTOR. SINGLE-ENDED, DC - 5.8 GHz. RMSOUT & Error vs. Pin @ 5800 MHz [1][2]
HMC909LP4E RMS POWER DETECTOR SINGLE-ENDED, DC - 5.8 GHz RMSOUT & Error vs Pin @ 5800 MHz [1][2]
HMC909LP4E
v02.0511
RMS POWER DETECTOR SINGLE-ENDED, DC - 5.8 GHz RMSOUT & Error vs. Pin @ 5800 MHz [1][2] RMSOUT & Error vs. Pin @ 3900 MHz [1][2]
2.4 4 2.4 4 2.15 3 ERR +25C 2.15 ERR +25C 3 ERR +85C ERR +85C ERR -40C 1.9 ERR -40C 2 1.9 2 1.65 1 ERROR 1.65 1 ERROR (V) (V) 1.4 0 1.4 0 (dB) (dB) 1.15 -1 1.15 -1 RMSOUT RMSOUT 0.9 -2 0.9 -2 Ideal Ideal 11 LOGOUT +25C LOGOUT +25C 0.65 LOGOUT +85C -3 0.65 LOGOUT +85C -3 LOGOUT -40C LOGOUT -40C 0.4 -4 0.4 -4 -50 -40 -30 -20 -10 -40 -30 -20 -10 INPUT POWER (dBm) INPUT POWER (dBm) t M s
Intercept vs. Frequency [1][2] Slope vs. Frequency [1][2]
- -40 80 rs 70 o -50 +25C +85C t -40C +25C (dBm) 60 +85C c -40C -60 (mV/dB) e 50 t SLOPE INTERCEPT e -70 40 D r -80 30 0 1000 2000 3000 4000 5000 6000 0 1000 2000 3000 4000 5000 6000 e FREQUENCY (MHz) FREQUENCY (MHz) w o P
RMSOUT vs. Pin with WCDMA RMSOUT Error vs. Pin with WCDMA 4 4 Carrier @ +25 °C [1] Carrier @ +25 °C [1]
2.5 4 100MHz 3 100MHz 2700MHz 2 900MHz 900MHz 3500MHz 1900MHz 1900MHz 3900MHz 2200MHz 2 2200MHz 5800MHz 2700MHz 3500MHz (V) 1.5 1 3900MHz (dB) 5800MHz 0 1 RMSOUT ERROR -1 -2 0.5 -3 0 -4 -70 -60 -50 -40 -30 -20 -10 0 -60 -50 -40 -30 -20 -10 INPUT POWER (dBm) INPUT POWER (dBm) [1] Data was taken at sci4=sci1=0V, sci3=sci2=5V, shortest integration time is for scI=0000, allowed longest integration time is for scI=1100 [2] wcDMA 4 carriers input waveform Info F rmoatr p ion rfiurcne is , d hed ebly ivAe n r al y a og D n evd t ice o p s is bla eli c eve o ed t rd o b e e ras: H ccuratite tiatne M d reli iac bl reo . w Ho av wev e C er, n o o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rporation, 20 Alpha Road, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd ho e ne r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o tniltie n .c e ao t m
11 - 5
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
