HMC1021LP4E v02.0511 RMS POWER DETECTOR &ENVELOPE TRACKER, DC - 3.9 GHzOutput Ripple & Rise/Fall Time vs. Integration SettingInput Return Loss vs. Frequency[Sci4,Sci3,Sci2,Sci1] in Decimal 0 1800 100000 Ripple with WCDMA1 -5 1500 Ripple with WCDMA4 10000 Ripple with 8 Tone (1kHz seperation) Rise Time & Fall Time (us) Ripple with 8 Tone (10kHz seperation) (dB) -10 1200 1000 LOSS -15 900 100 -20 600 10 RETURN Rise Time 1 -25 300 Fall Time Output Ripple Peak-Peak (mV) 0 0.1 -30 0 1 2 3 4 5 6 0 1 2 3 4 5 6 7 8 9 10 11 12 11 FREQUENCY (GHz) Integration Setting (in Decimal) t ETOUT & ETOUT Error vs. Pin with CW @ M ETOUT vs. Pin with CW @ 900 MHz900 MHz s 2.5 10 4 - +25C +85C 2 1 -40C 2 rs ERROR (dB) o t 1.5 0.1 0 c ETOUT (V) e +25C 1 -2 +85C Normalized ETOUT (V) 0.01 t -40C Error +25C Error +85C e Error -40C 0.001 -4 0.5 D 0 0.05 0.1 0.15 0.2 -40 -35 -30 -25 -20 -15 -10 -5 r INPUT VOLTAGE (Vp-p) INPUT POWER (dBm) e w o ETOUT & ETOUT Error vs. Pin with CW @ETOUT vs. Pin with CW @ 1900 MHz P 1900 MHz 2.5 10 4 +25C +85C 2 1 -40C 2 ERROR (dB) 1.5 0.1 0 ETOUT (V) +25C 1 -2 +85C Normalized ETOUT (V) 0.01 -40C Error +25C Error +85C Error -40C -4 0.5 0.001 0 0.05 0.1 0.15 0.2 -40 -35 -30 -25 -20 -15 -10 -5 INPUT VOLTAGE (Vp-p) INPUT POWER (dBm) For price, delivery and to place orders: Hittite Microwave Corporation, 20 Alpha Road, Chelmsford, MA 01824 Phone: 978-250-3343 Fax: 978-250-3373 Order On-line at www.hittite.com 11 - 8 Application Support: Phone: 978-250-3343 or apps@hittite.com Document Outline Typical Applications Features Functional Diagram General Descriptions Electrical Specifications I Electrical Specifications II RMSOUT vs. Pin with Different Modulations @ 1900 MHz RMSOUT Error vs. Pin with Different Modulations @ 1900 MHz Electrical Specifications III Typical Performance Characteristics RMSOUT & Error vs. Pin @ 100 MHz RMSOUT & Error vs. Pin @ 900 MHz RMSOUT & Error vs. Pin @ 1900 MHz RMSOUT & Error vs. Pin @ 2200 MHz RMSOUT & Error vs. Pin @ 2700 MHz RMSOUT & Error vs. Pin @ 3500 MHz RMSOUT & Error vs. Pin @ 3900 MHz RMSOUT Intercept vs. Frequency RMSOUT Slope vs. Frequency RMSOUT vs. Pin with WCDMA 4 Carrier @ +25 °C RMSOUT Error vs. Pin with WCDMA 4 Carrier @ +25 °C RMSOUT Error vs. Pin with WCDMA 4 Carrier @ +85 °C wrt +25 °C Response RMSOUT Error vs. Pin with WCDMA 4 Carrier @ -40 °C wrt +25 °C Response RMSOUT vs. Pin with CW @ +25 °C RMSOUT Error vs. Pin with CW @ +25 °C RMSOUT vs. Pin w/ CW & WCDMA 4 Carrier @ 1900 MHz & +25 °C Reading Error for WCDMA 4 Carrier wrt CW Response @ +25 °C RMSOUT vs. Pin w/ CW & WCDMA 4 Carrier @ 1900 MHz & +85 °C Reading Error for WCDMA 4 Carrier wrt CW Response @ +85 °C RMSOUT vs. Pin w/ CW & WCDMA 4 Carrier @ 1900 MHz & -40 °C Reading Error for WCDMA 4 Carrier wrt CW Response @ -40 °C RMSOUT Output Response with SCI = 0000 @ 1900 MHz RMSOUT Output Response with SCI = 1100 @ 1900 MHz Typical Supply Current vs. Pin, Vcc = 5V Input Return Loss vs. Frequency Output Ripple & Rise/Fall Time vs. Integration Setting [Sci4,Sci3,Sci2,Sci1] in Decimal ETOUT vs. Pin with CW @ 900 MHz ETOUT & ETOUT Error vs. Pin with CW @ 900 MHz ETOUT & ETOUT Error vs. Pin with CW @ 1900 MHz ETOUT vs. Pin with CW @ 3500 MHz ETOUT & ETOUT Error vs. Pin with CW @ 3500 MHz ETOUT Intercept vs. Frequency with CW ETOUT Slope vs. Frequency with CW Absolute Maximum Ratings Outline Drawing Package Information Pin Descriptions Evaluation PCB List of Materials Application Circuit Application Information Principle of Operation Configuration For The Typical Application Broadband Single-Ended Input Interface RMSOUT & Error vs. Pin Envelope Detector Output ETOUT Bandwidth ETOUT Response to an RF Input Signal with a 100 MHz Modulation Bandwidth RMS Output Interface and Transient Response Table 1: Transient Response vs. SCI Setting Rise Time vs. SCI Setting over Input Power Rise Settling Time vs. SCI Setting over Input Power Fall Time vs. SCI Setting over Input Power Residual Ripple for 900 MHz WiMAX @ SCI=0100 Residual Ripple for 900 MHz WiMAX @ SCI=0101 Residual Ripple for 900 MHz WiBRO @ SCI=0100 Residual Ripple for 900 MHz WiBRO@ SCI=0110 Residual Ripple for 900 MHz LTE Downlink @ SCI=0100 Residual Ripple for 900 MHz LTE Downlink @ SCI=0110 Residual Ripple for 900 MHz WCDMA4 @ SCI=0011 Residual Ripple for 900 MHz WCDMA4 @ SCI=0100 LOG-Slope and Intercept Slope Adjustment Intercept Adjustment DC Offset Compensation Loop Standby Mode Modulation Performance - Crest factor performance Reading Error for WCDMA 4 Carrier wrt CW Response @ +25 °C Reading Error for WCDMA 4 Carrier wrt CW Response @ 2200 MHz RMSOUT Error vs. Crest Factor over Frequency System Calibration Layout Considerations Definitions
