Datasheet HMC1010LP4E (Analog Devices) - 8
DescriptionRMS Power Detector SMT, DC - 3.9 GHz
Pages / Page24 / 8 — HMC1010LP4E. RMS POWER DETECTOR. DC - 3.9 GHz. Output Ripple & …
File Format / SizePDF / 2.8 Mb
HMC1010LP4E. RMS POWER DETECTOR. DC - 3.9 GHz. Output Ripple & Rise/Fall Time vs. Integration Setting
HMC1010LP4E RMS POWER DETECTOR DC - 3.9 GHz Output Ripple & Rise/Fall Time vs Integration Setting
HMC1010LP4E
v03.0511
RMS POWER DETECTOR DC - 3.9 GHz Output Ripple & Rise/Fall Time vs. Integration Setting Input Return Loss vs. Frequency [Sci4,Sci3,Sci2,Sci1] in Decimal
0 1800 100000 Ripple with WCDMA4TM -5 1500 Ripple with WCDMA1TM 10000 Ripple with 8 Tone (1kHz seperation) Rise Time & Fall Time (us) Ripple with 8 Tone (10kHz seperation) -10 (dB) 1200 1000 -15 LOSS 900 100 -20 Defined in large part by balun: 600 10 RETURN -25 M/A-Com balun #ETC1-1-113; 4.5 MHz to 3000 MHz Rise Time 300 Fall Time 1 -30 Output Ripple Peak-Peak (mV) -35 0 0.1 0 1 2 3 4 5 6 11 0 1 2 3 4 5 6 7 8 9 10 11 12 FREQUENCY (GHz) Integration Setting (in Decimal) t M s - rs o t c e t e D r e w o P Info F rmoatr p ion rfiurcne is , d hed ebly ivAe n r al y a og D n evd t ice o p s is bla eli c eve o ed t rd o b e e ras: H ccuratite tiatne M d reli iac bl reo . w Ho av wev e C er, n o o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rporation, 20 Alpha Road, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd ho e ne r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o tniltie n .c e ao t m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com
11 - 8
Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
