Datasheet ADL5504 (Analog Devices) - 9
Description450 MHz TO 6000 MHz TruPwr Detector
Pages / Page24 / 9 — ADL5504. R (. RRO. –25. –20. –15. –10. INPUT (dBm)
RevisionA
ADL5504 R ( RRO –25 –20 –15 –10 INPUT (dBm)
ADL5504 3 3 2 2 1 1 B) B) d d R ( 0 R ( 0 RRO RRO E E –1 –1 –2 –2 –3 –3 –25 –20 –15 –10 –5 0 5 10 15
010
013
INPUT (dBm) INPUT (dBm)
08437- 08437- Figure 10. Output Temperature Drift from +25°C Linear Reference Figure 13. Output Delta from +25°C Output Voltage for for 50 Devices at −40°C, +25°C, and +85°C, 450 MHz Frequency 50 Devices at −40°C and +85°C, 450 MHz Frequency
011
014
08437- 08437- Figure 11. Output Temperature Drift from +25°C Linear Reference Figure 14. Output Delta from +25°C Output Voltage for for 50 Devices at −40°C, +25°C, and +85°C, 900 MHz Frequency 50 Devices at −40°C and +85°C, 900 MHz Frequency
012
015
08437- 08437- Figure 12. Output Temperature Drift from +25°C Linear Reference Figure 15. Output Delta from +25°C Output Voltage for for 50 Devices at −40°C, +25°C, and +85°C, 1900 MHz Frequency 50 Devices at −40°C and +85°C, 1900 MHz Frequency Rev. A | Page 9 of 24 Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Circuit Description RMS Circuit Description and Filtering Filtering Output Buffer Applications Information Basic Connections RF Input Interfacing Resistive Tap RF Input Multiple RF Inputs Linearity Output Swing Output Offset Output Drive Capability and Buffering Selecting the Square-Domain Filter and Output Low-Pass Filter Power Consumption, Enable, and Power-On/Power-Off Response Time Device Calibration and Error Calculation Calibration for Improved Accuracy Drift over a Reduced Temperature Range Device Handling Evaluation Board Land Pattern and Soldering Information Outline Dimensions Ordering Guide
