link to page 8 link to page 8 link to page 8 link to page 8 link to page 8 link to page 8 link to page 8 link to page 8 link to page 8 link to page 8 link to page 8 link to page 8 link to page 8 link to page 8 link to page 8 link to page 8 link to page 8 link to page 8 link to page 8 link to page 8 link to page 8 link to page 8 link to page 8 link to page 8 link to page 8 link to page 8 link to page 8 ADL5501Parameter ConditionMinTypMaxUnit RMS CONVERSION (f = 5000 MHz) Input RFIN to Output VRMS Input Impedance +51||−0.2 Ω||pF Input Return Loss 17 dB Dynamic Range1 CW input, −40°C < TA < +85°C ±0.25 dB Error4 Delta from 25°C, VS = 5 V 5 dB ±0.25 dB Error2 VS = 3 V 5 dB VS = 5 V 5 dB ±1 dB Error2 VS = 3 V 31 dB VS = 5 V 35 dB ±2 dB Error2 VS = 3 V 34 dB VS = 5 V 38 dB Maximum Input Level ±1 dB error2 15 dBm Minimum Input Level ±1 dB error2 −20 dBm Conversion Gain VOUT = (gain × VIN) + intercept 3.3 V/V rms Output Intercept3 0.02 V Output Voltage—High Power In PIN = 5 dBm, 400 mV rms 1.33 V Output Voltage—Low Power In PIN = –21 dBm, 20 mV rms 0.08 V Temperature Sensitivity PIN = –5 dBm 25°C ≤ TA ≤ 85°C 0.0001 dB/°C −40°C ≤ TA ≤ +25°C −0.0031 dB/°C RMS CONVERSION (f = 6000 MHz) Input RFIN to Output VRMS Input Impedance +86||−0.1 Ω||pF Input Return Loss 10.1 dB Dynamic Range1 CW input, −40°C < TA < +85°C ±0.25 dB Error4 Delta from 25°C, VS = 5 V 25 dB ±0.25 dB Error2 VS = 3 V 20 dB VS = 5 V 20 dB ±1 dB Error2 VS = 3 V 31 dB VS = 5 V 31 dB ±2 dB Error2 VS = 3 V 35 dB VS = 5 V 35 dB Maximum Input Level ±1 dB error2 14 dBm Minimum Input Level ±1 dB error2 −17 dBm Conversion Gain VOUT = (gain × VIN) + intercept 2.4 V/V rms Output Intercept3 0.02 V Output Voltage—High Power In PIN = 5 dBm, 400 mV rms 0.97 V Output Voltage—Low Power In PIN = –21 dBm, 20 mV rms 0.07 V Temperature Sensitivity PIN = –5 dBm 25°C ≤ TA ≤ 85°C 0.0017 dB/°C −40°C ≤ TA ≤ +25°C −0.0008 dB/°C Rev. B | Page 7 of 28 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS CIRCUIT DESCRIPTION FILTERING APPLICATIONS INFORMATION BASIC CONNECTIONS OUTPUT SWING LINEARITY INPUT COUPLING USING A SERIES RESISTOR MULTIPLE RF INPUTS SELECTING THE SQUARE-DOMAIN FILTER AND OUTPUT LOW-PASS FILTER POWER CONSUMPTION, ENABLE, AND POWER-ON/POWER-OFF RESPONSE TIME OUTPUT DRIVE CAPABILITY AND BUFFERING VRMS OUTPUT OFFSET DEVICE CALIBRATION AND ERROR CALCULATION CALIBRATION FOR IMPROVED ACCURACY DRIFT OVER A REDUCED TEMPERATURE RANGE OPERATION BELOW 100 MHz EVALUATION BOARD OUTLINE DIMENSIONS ORDERING GUIDE
