Datasheet AD9363 (Analog Devices) - 4
DescriptionRF Agile Transceiver
Pages / Page32 / 4 — AD9363. Data Sheet. Parameter1. Symbol Min. Typ. Max. Unit. Test …
RevisionD
File Format / SizePDF / 529 Kb
AD9363. Data Sheet. Parameter1. Symbol Min. Typ. Max. Unit. Test Conditions/Comments
AD9363 Data Sheet Parameter1 Symbol Min Typ Max Unit Test Conditions/Comments
link to page 5
RX2x_x to RX1x_x Isolation RX2A_x to RX1A_x, RX2C_x to RX1C_x 65 dB RX2B_x to RX1B_x 50 dB RECEIVERS, 3.5 GHz Noise Figure NF 3.3 dB Maximum Rx gain Third-Order Input Intermodulation IIP3 −15 dBm Maximum Rx gain Intercept Point Second-Order Input Intermodulation IIP2 44 dBm Maximum Rx gain Intercept Point Local Oscillator (LO) Leakage −100 dBm At Rx front-end input Quadrature Gain Error 0.2 % Phase Error 0.2 Degrees Modulation Accuracy (EVM) −34 dB 40 MHz reference clock Input Return Loss S11 −10 dB RX1x_x to RX2x_x Isolation RX1A_x to RX2A_x, RX1C_x to RX2C_x 60 dB RX1B_x to RX2B_x 48 dB RX2x_x to RX1x_x Isolation RX2A_x to RX1A_x, RX2C_x to RX1C_x 60 dB RX2B_x to RX1B_x 48 dB TRANSMITTERS, GENERAL Center Frequency 325 3800 MHz Tx Bandwidth 20 MHz Power Control Range 90 dB Power Control Resolution 0.25 dB TRANSMITTERS, 800 MHz Output Return Loss S22 −10 dB Maximum Output Power 8 dBm 1 MHz tone into 50 Ω load Modulation Accuracy (EVM) −34 dB 19.2 MHz reference clock Third-Order Output Intermodulation OIP3 23 dBm Intercept Point Carrier Leakage −50 dBc 0 dB attenuation −32 dBc 40 dB attenuation Noise Floor −157 dBm/Hz 90 MHz offset Isolation TX1x_x to TX2x_x 50 dB TX2x_x to TX1x_x 50 dB TRANSMITTERS, 2.4 GHz Output Return Loss S22 −10 dB Maximum Output Power 7.5 dBm 1 MHz tone into 50 Ω load Modulation Accuracy (EVM) −34 dB 40 MHz reference clock Third-Order Output Intermodulation OIP3 19 dBm Intercept Point Carrier Leakage −50 dBc 0 dB attenuation −32 dBc 40 dB attenuation Noise Floor −156 dBm/Hz 90 MHz offset Isolation TX1x_x to TX2x_x 50 dB TX2x_x to TX1x_x 50 dB TRANSMITTERS, 3.5 GHz Output Return Loss S22 −10 dB Maximum Output Power 7.0 dBm 1 MHz tone into 50 Ω load Modulation Accuracy (EVM) −34 dB 40 MHz reference clock Rev. D | Page 4 of 32 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS CURRENT CONSUMPTION—VDD_INTERFACE CURRENT CONSUMPTION—VDDx (COMBINATION OF ALL 1.3 V SUPPLIES) ABSOLUTE MAXIMUM RATINGS REFLOW PROFILE THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS 800 MHZ FREQUENCY BAND 2.4 GHZ FREQUENCY BAND THEORY OF OPERATION GENERAL RECEIVER TRANSMITTER CLOCK INPUT OPTIONS SYNTHESIZERS RF PLLs BB PLL DIGITAL DATA INTERFACE DATA_CLK Signal FB_CLK Signal RX_FRAME and TX_FRAME Signals ENABLE STATE MACHINE SPI Control Mode Pin Control Mode SPI INTERFACE CONTROL PINS Control Outputs (CTRL_OUT7 to CTRL_OUT0) Control Inputs (CTRL_IN3 to CTRL_IN0) GPO PINS (GPO_3 TO GPO_0) AUXILIARY CONVERTERS AUXADC AUXDAC1 and AUXDAC2 POWERING THE AD9363 APPLICATIONS INFORMATION PACKAGING AND ORDERING INFORMATION OUTLINE DIMENSIONS ORDERING GUIDE
