ADN8833Data SheetTENSW33TEC CURRENT4LDO (TEC+)LDO (TEC–)1PWM (TEC+)PWM (TEC–)21 121 102 CH1 1VCH2 1VCH3 2VM20.0msA CH3 800mVCH1 20mVBW CH2 20mV BM400nsA CH3 1.00VWCH4 500mA ΩT 40msCH3 2.0V BT 0.0s 12909- W 12909- Figure 16. Typical Enable Waveforms in Cooling Mode, VIN = 3.3 V, Figure 18. Typical Switch and Voltage Ripple Waveforms in Cooling Mode, Load = 2 Ω, TEC Current = 1 A VIN = 3.3 V, Load = 2 Ω, TEC Current = 1 A TENSW33TEC CURRENT4LDO (TEC+)1PWM (TEC–)PWM (TEC–)2LDO (TEC+)2 122 103 CH1 1VCH2 1VCH3 2VM20.0msA CH3 800mVCH1 20mVBW CH2 20mV BM400nsA CH3 1.00VWCH4 500mA ΩT 40msCH3 2.0V BT 0.0s 12909- W 12909- Figure 17. Enable Waveforms in Heating Mode, VIN = 3.3 V, Figure 19. Typical Switch and Voltage Ripple Waveforms in Heating Mode, Load = 2 Ω, TEC Current = 1 A VIN = 3.3 V, Load = 2 Ω, TEC Current = 1 A Rev. B | Page 10 of 23 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS DETAILED FUNCTIONAL BLOCK DIAGRAM THEORY OF OPERATION DIGITAL PID CONTROL POWERING THE DRIVER ENABLE AND SHUTDOWN OSCILLATOR CLOCK FREQUENCY External Clock Operation Connecting Multiple ADN8833 Devices SOFT START ON POWER-UP TEC VOLTAGE/CURRENT MONITOR Voltage Monitor Current Monitor MAXIMUM TEC VOLTAGE LIMIT Using a Resistor Divider to Set the TEC Voltage Limit MAXIMUM TEC CURRENT LIMIT Using a Resistor Divider to Set the TEC Current Limit APPLICATIONS INFORMATION TYPICAL APPLICATION WITH DIGITAL PID USING A DAC THERMISTOR SETUP MOSFET DRIVER AMPLIFIERS PWM OUTPUT FILTER REQUIREMENTS Inductor Selection Capacitor Selection INPUT CAPACITOR SELECTION POWER DISSIPATION PWM Regulator Power Dissipation Conduction Loss (PCOND) Switching Loss (PSW) Transition Loss (PTRAN) Linear Regulator Power Dissipation PCB LAYOUT GUIDELINES BLOCK DIAGRAMS AND SIGNAL FLOW GUIDELINES FOR REDUCING NOISE AND MINIMIZING POWER LOSS General PCB Layout Guidelines PWM Power Stage Layout Guidelines Linear Power Stage Layout Guidelines EXAMPLE PCB LAYOUT USING TWO LAYERS OUTLINE DIMENSIONS ORDERING GUIDE
