Datasheet RN4677 (Microchip) - 6
ManufacturerMicrochip
DescriptionBluetooth 4.0 Dual Mode Module
Pages / Page28 / 6 — RN4677. TABLE 1-2:. PIN DESCRIPTION (CONTINUED). RN4677 RN4677U. Name. …
File Format / SizePDF / 508 Kb
RN4677. TABLE 1-2:. PIN DESCRIPTION (CONTINUED). RN4677 RN4677U. Name. Type. Description. Pin. Note:. 1.2. Configuring the RN4677. 1.4
RN4677 TABLE 1-2: PIN DESCRIPTION (CONTINUED) RN4677 RN4677U Name Type Description Pin Note: 1.2 Configuring the RN4677 1.4
link to page 6 link to page 8 link to page 8 link to page 18 link to page 12 link to page 12
RN4677 TABLE 1-2: PIN DESCRIPTION (CONTINUED) RN4677 RN4677U Name Type Description Pin Pin
31 29 GND Power Ground reference — 30 BT_RF AIO External antenna connection (50 Ohm) 32 — GND Power Ground reference 33 — GND Power Ground reference
Note:
Pin type abbreviation: A = Analog, D = Digital, I = Input, O = Output.
1.2 Configuring the RN4677 1.4 Control and Indication I/O Pins
Configuring the RN4677 features are performed using The configurable control and indication I/O pins are either RN-style ASCII command documented in the P00, P05, P17, P31, P32, P33, P34 and P37. The “RN4677 Bluetooth® Low Energy Dual Mode Module RN4677 uses control signal as the input, whereas User’s Guide”. Alternatively, it is possible to configure indication signals are the output. Table 1-3 shows the RN4677 using the interface as described in configurable I/O pin assignments to the control and
Section 2.2 “External Configuration and
indication signals.
Programming”
, along with either external PC
Note:
RTS is only assigned to P00 and CTS to configuration utility (UI Tool or EEPROM Tool), or the PIC MCU configuration library. For more information, P17. visit www.microchip.com/rn4677.
TABLE 1-3: CONFIGURATION AND 1.3 UART Interface INDICATION I/O
Figure 1-4 and Figure 1-5 show power and MCU
ASSIGNMENTS
interface examples.
Pin Name Default Configuration
The RN4677 UART pins TXD and RXD connect to the P00 UART_RTS UART pins of the host MCU. It is highly recommended to use hardware flow control pins RTS and CTS. By P05 NO_USE default, the RN4677 hardware flow control is disabled P17 UART_CTS and must be configured to become enabled. The UART P31 INQUIRY_CONFIGURE Baud is configurable and the available signal rates are P32 LINK_DROP listed in Table 4-5. P33 UART_RX_IND P34 PAIRING_KEY P37 LOW_BATTERY_IND DS50002370A-page 6
Advance Information
 2015 Microchip Technology Inc. Document Outline Bluetooth® 4.0 Dual Mode Module Features Operational RF/Analog Data Throughput MAC/Baseband/Higher Layer Antenna Compliance General Description Applications Table of Contents Most Current Data Sheet Errata Customer Notification System 1.0 Device Overview TABLE 1-1: RN4677 Module Family Types FIGURE 1-1: RN4677 Block Diagram 1.1 Interface Description FIGURE 1-2: RN4677 PIN Diagram FIGURE 1-3: RN4677U PIN Diagram TABLE 1-2: PIN Description 1.2 Configuring the RN4677 1.3 UART Interface 1.4 Control and Indication I/O Pins TABLE 1-3: Configuration And Indication I/O Assignments 1.5 Status Indication I/O Pins TABLE 1-4: Status Indication 1.6 Software Button (SW_BTN) 1.7 WAKE UP (WAKEUP) 1.8 RESET (RST_N) 1.9 Status LED (LED1) 1.10 System Configuration 1.11 Power TABLE 1-5: system configuration settings FIGURE 1-4: RN4677 To MCU Interface Example - LDO FIGURE 1-5: RN4677 To MCU Interface Example - Battery 1.12 Mounting Details 1.13 Soldering Recommendations FIGURE 1-6: RN4677 Module Dimensions FIGURE 1-7: RN4677 Recommended PCB Footprint FIGURE 1-8: RN4677 Host PCB Mounting Suggestion 2.0 Application Information 2.1 RN4677 Ceramic Chip Antenna FIGURE 2-1: RN4677 Antenna Radiation Pattern 2.2 External Configuration and Programming FIGURE 2-2: External Programming Header Connections 3.0 Regulatory Approval 3.1 United States 3.1.1 LABELING AND USER INFORMATION REQUIREMENTS 3.1.2 RF EXPOSURE 3.1.3 HELPFUL WEB SITES 3.2 Canada 3.2.1 LABELING AND USER INFORMATION REQUIREMENTS 3.2.2 RF EXPOSURE 3.2.3 APPROVED EXTERNAL ANTENNA TYPES 3.2.4 HELPFUL WEB SITES 3.3 Europe 3.3.1 LABELING AND USER INFORMATION REQUIREMENTS 3.3.2 EXTERNAL ANTENNA REQUIREMENTS 3.3.3 HELPFUL WEB SITES TABLE 3-1: European Compliance Testing 4.0 Electrical Characteristics TABLE 4-1: Environmental Conditions TABLE 4-2: Electrical Characteristics TABLE 4-3: Supply Consumption-Classic(1) TABLE 4-4: Supply Consumption-low Energy(1) TABLE 4-5: UART Baud 5.0 Ordering Information TABLE 5-1: Ordering Information Appendix A: Revision History Revision A (May 2015) The Microchip Web Site Customer Change Notification Service Customer Support Product Identification System Worldwide Sales and Service
