Datasheet RN4678 (Microchip) - 8
ManufacturerMicrochip
DescriptionBluetooth Dual Mode Module
Pages / Page35 / 8 — RN4678. 2.5. Software Button (SW_BTN). Note:. FIGURE 2-2:. SW_BTN TIME …
RN4678. 2.5. Software Button (SW_BTN). Note:. FIGURE 2-2:. SW_BTN TIME (HIGH) AT APP MODE(1,2. Note 1:
RN4678 2.5 Software Button (SW_BTN) Note: FIGURE 2-2: SW_BTN TIME (HIGH) AT APP MODE(1,2 Note 1:
link to page 8 link to page 9 link to page 8 link to page 8
Figure 2-2 through Figure 2-4 show the timing diagrams for the RN4678 with regard to the SW_BTN The Software Button (SW_BT) pin powers the main and the other relevant pins in different states of the sections of the module into operation. If the SW_BTN module. pin is low, the module is turned off. After turning the module on via the SW_BTN, the host MCU must wait for specific time before sending the first command. The timing diagrams for the SW_BTN, other related pins, and the time delay are required before the host MCU sends the first command.
Note:
By default, the SW_BTN functionality is disabled and it can be enabled using the Host MCU commands. Refer to the RN4678 Command Reference User Guide (DS50002506) for more details.
FIGURE 2-2: SW_BTN TIME (HIGH) AT APP MODE(1,2 )
BAT_IN Power on MCU State Idle Power on /Initial SW_BTN LDO18_O 10 ms 40 ms RST_N 4 ms P1_5 P0_4 UART MCU send UART command command (BT UART RX) 475 ms
Note 1:
Time duration (475 ms) is for reference purposes only. Use the Status Indication pins to verify the exact time when the host MCU can start sending the commands.
2:
Reset pin is not connected.  2016-2020 Microchip Technology Inc. DS50002519E-page 8 Document Outline RN4678 Features RF/Analog Data Throughput Operating Conditions MAC/Baseband/Higher Layer Features Applications Description Table of Contents Most Current Data Sheet Errata Customer Notification System 1.0 Device Overview FIGURE 1-1: RN4678 Internal Block Diagram TABLE 1-1: PIN Description FIGURE 1-2: RN4678 PIN DIAGRAM 2.0 Application Information 2.1 Module Configuration 2.2 Flow Control 2.3 Control and Indication I/O Pins 2.4 Power Tree FIGURE 2-1: Power Tree Diagram 2.5 Software Button (SW_BTN) FIGURE 2-2: SW_BTN TIME (HIGH) AT APP MODE(1,2) FIGURE 2-3: SW_BTN TIME (LOW) AT ACCESS STATES(1) FIGURE 2-4: SW_BTN TIME (LOW) AT LINK STATES(1,2) 2.6 WAKE-UP FIGURE 2-5: WAKE-UP TIME(1) 2.7 External Reset FIGURE 2-6: TIMING WAVEFORMS ON RESET (1,2) 2.8 LED Driver FIGURE 2-7: LED Driver 2.9 Host MCU Interface over UART FIGURE 2-8: Power and MCU Interface Example for Rn4678 2.10 Reference Circuit FIGURE 2-9: RN4678 Reference Circuit 3.0 Electrical Characteristics Absolute Maximum Ratings TABLE 3-1: Recommended Operating Conditions TABLE 3-2: 3.3V LDO Electrical Parameters (1,2) TABLE 3-3: PMU LDO(1,2) TABLE 3-4: SAR-ADC AND Battery Voltage Detector TABLE 3-5: Intensity Controllable LED Driver TABLE 3-6: Power Consumption-Classic(1) TABLE 3-7: Power Consumption-Low Energy(1,2) 4.0 Radio Characteristics TABLE 4-1: Transmitter Performance (1,2) TABLE 4-2: Receiver Performance(1) 5.0 Physical Dimensions FIGURE 5-1: RN4678 Module Dimensions FIGURE 5-2: RN4678 Recommended PCB Footprint FIGURE 5-3: RN4678 Host PCB Mounting Suggestion 6.0 Reflow profile FIGURE 6-1: Reflow Profile 7.0 Module Placement FIGURE 7-1: Module Placement Examples TABLE 7-1: Recommended Antenna FIGURE 7-2: Keep Out Area Recommended for Antenna 7.1 RN4678 Ceramic Chip Antenna FIGURE 7-3: RN4678 Antenna Radiation Pattern 8.0 Ordering Information TABLE 8-1: Ordering Information 9.0 Regulatory Approval 9.1 United States 9.2 Canada 9.3 Europe TABLE 9-1: EUROPEAN COMPLIANCE TESTING 9.4 Japan 9.5 Korea 9.6 Taiwan 9.7 China 9.8 Other Regulatory Information Appendix A: Revision History The Microchip WebSite Product Identification System Trademarks Worldwide Sales
