Datasheet AS2333 (Diodes) - 5
ManufacturerDiodes
Description1.8V, Micropower CMOS Zero-Drift Operational Amplifiers
Pages / Page14 / 5 — AS2333. Typical Performance Characteristics. Small Signal Response Small …
File Format / SizePDF / 788 Kb
AS2333. Typical Performance Characteristics. Small Signal Response Small Signal Response
AS2333 Typical Performance Characteristics Small Signal Response Small Signal Response
(continued)
Unity Gain Unity Gain VS = 5.0V VS = 5.0V RL = 10kΩ RL = 10kΩ CL = 100pF CL = 220pF V V IN IN 100mV/div 100mV/div VOUT VOUT 100mV/div 100mV/div Time 10μs/div Time 10μs/div
Negative Overvoltage Response Positive Overvoltage Response
V+ = 2.5V, V- = -2.5V V+ = 2.5V, V- = -2.5V Av = -10 V Av = -10 IN VIN 1V/div 1V/div VOUT 500mV/div VOUT 500mV/div Time 50μs/div Time 50μs/div
Output Voltage Swing from Rail Voltage Noise Spectral Density
70 1000 65 V = 5.0V S z) 60 R = 10k to V / 2 H L S 55 il (mV) V/ a (n R 50 y t m 100 45 si n fro e 40 Positive g D in l 35 ra Sw ct 30 e g 25 Spe lta 10 20 sei t Vo o u 15 Negative N tp e u 10 g O at 5 Vol 1 0 -40 -25 -10 5 20 35 50 65 80 95 110 125 100 1k 10k Ambient Temperature (OC) Frequen cy (Hz) AS2333 5 of 14 June 2020 Document number: DS42770 Rev. 2 - 2
www.diodes.com
© Diodes Incorporated
