Datasheet ICS-40638 (TDK)
ManufacturerTDK
DescriptionHigh AOP Analog MEMS Microphone with Differential Output
Pages / Page14 / 1 —   ICS‐40638.   GENERAL DESCRIPTION . APPLICATIONS . FEATURES . SPEC . …
File Format / SizePDF / 391 Kb
  ICS‐40638.   GENERAL DESCRIPTION . APPLICATIONS . FEATURES . SPEC . PERFORMANCE . SNR . Current . AOP . FUNCTIONAL BLOCK DIAGRAM
Datasheet ICS-40638 TDK
    ICS‐40638
  GENERAL DESCRIPTION  APPLICATIONS
The ICS‐40638 is an analog MEMS microphone with very high  Automotive   dynamic range and capable of operation up to 105°C. The ICS‐ Still and video cameras  40638 includes a MEMS microphone element, an impedance  IoT devices  converter, and a differential output amplifier.         Other high‐performance specifications include 138 dB SPL    acoustic overload point, tight ±1 dB sensitivity tolerance and    enhanced immunity to both radiated and conducted RF    interference.
FEATURES
The ICS‐40638 is available in a small 3.50 mm × 2.65 mm ×    0.98 mm bottom port surface‐mount package.
SPEC  PERFORMANCE
SNR
63 dBA
Current
170 µA
AOP
138 SPL    Differential non‐inverting analog output  −43 dBV sensitivity (differential)  ±1 dB sensitivity tolerance  Extended frequency response from 35 Hz to 20 kHz  Enhanced RF immunity  −81 dB PSRR   3.50 × 2.65 × 0.98 mm surface‐mount package  Compatible with Sn/Pb and Pb‐free solder processes   RoHS/WEEE compliant
FUNCTIONAL BLOCK DIAGRAM  ORDERING INFORMATION
PART  TEMP RANGE  PACKAGING  ICS‐40638
−40°C to +105°C  13” Tape and Reel
EV_ICS‐40638‐FX
InvenSense Inc.
InvenSense, Inc. reserves the right to change the  1745 Technology Drive, San Jose, CA 95110 U.S.A  Document Number: DS‐000281  detail specifications as may be required to permit  +1(408) 988–7339  Revision: 1.1  improvements in the design of its products.  www.invensense.com  Rev Date: 4/15/2020
