Datasheet CT220 (Crocus Technology) - 4
Manufacturer | Crocus Technology |
Description | XtremeSense High Linearity, High-Resolution Contactless Current Sensor in Miniature Form Factor |
Pages / Page | 22 / 4 — CT220 www.crocus-technology.com Absolute Maximum Ratings |
File Format / Size | PDF / 1.2 Mb |
Stresses exceeding the absolute maximum ratings may damage the CT220 and may not function or be operable above the
recommended operating conditions and stressing the parts to these levels is not recommended. In addition, extended exposure
to stresses above the recommended operating conditions may affect device reliability. The absolute maximum ratings are
stress ratings only. Symbol
VDD
VFLAG#_PP
VI/O
IIN / IOUT Parameter Min. Max. Unit Supply Voltage strength -0.3 6.0 V Push-pull Output (Active LOW) -0.3 VDD + 0.3 V Input/Output Pins Maximum Voltage -0.3 VDD + 0.3 V ±10.0 mA Input and Output Current ESD Electrostatic Discharge
Protection Level TJ Junction Temperature -40 +150 °C TSTG Storage Temperature -65 +150 °C +260 °C TL Human Body Model (HBM) per
JESD22-A114 kV ±2.0 Lead Soldering Temperature, 10 Seconds Recommended Operating Conditions
The Recommended Operating Conditions table defines the conditions for actual operation of the CT220. Recommended
operating conditions are specified to ensure optimal performance to the specifications. Crocus Technology does not
recommend exceeding them or designing to absolute maximum ratings. Symbol Parameter Min. Typ. Max. Unit 5.0 5.5 V VDD V ±3.0 mA VDD Supply Voltage Range 2.7 VOUT Output Voltage Range 0 IOUT Output Current TA Operating Ambient Temperature © 2020 Crocus Technology
CT220 Rev. 0.0 Industrial -40 +25 +85 Extended Industrial -40 +25 +125 °C 4
