Datasheet ADCMP380 (Analog Devices)
Description | Ultralow Power Voltage Comparator with Reference |
Pages / Page | 10 / 1 — Ultralow Power Voltage Comparator. with Reference. Data Sheet. ADCMP380. … |
Revision | A |
File Format / Size | PDF / 237 Kb |
Ultralow Power Voltage Comparator. with Reference. Data Sheet. ADCMP380. FEATURES. FUNCTIONAL BLOCK DIAGRAM
Ultralow Power Voltage Comparator with Reference Data Sheet ADCMP380 FEATURES FUNCTIONAL BLOCK DIAGRAM Comparator with on-chip reference VCC Ultralow power consumption with ICC = 92 nA (typical) ADCMP380 Precision low voltage monitoring down to 0.5 V EN Accurate internal reference level over full temperature range IN OUT ±1.6% at 1 V ±2.2% at 0.5 V REF Enable input
001
23 µs typical propagation delay GND
12783-
Open-drain type output
Figure 1.
Input glitch immunity Available in a 1.46 mm × 0.96 mm WLCSP Operational temperature range: −40°C to +85°C APPLICATIONS Portable/battery-operated equipment Battery monitors Energy harvesting GENERAL DESCRIPTION
The ADCMP380 is an ultralow power voltage comparator with The ADCMP380 is available in a 6-bal , 1.46 mm × 0.96 mm internal reference suitable for use in general-purpose applications. WLCSP and is specified over the temperature range of −40°C The ultralow power consumption of this device makes it suitable to +85°C. for power efficiency sensitive systems, such as battery-powered portable devices and energy meters.
Table 1. Selection Table Part No. Reference Voltage (V) Output
The ADCMP380 is available with a 0.5 V and 1 V internal ADCMP380-1 1 Open-drain reference with ±2.2% and ±1.6% accuracy, respectively, over the ADCMP380-2 0.5 Open-drain ful temperature range; this internal reference enables the device to monitor the node of interest accurately to 0.5 V. The enable input allows the user to hold the output low regardless of the state of the input.
Rev. A Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2015–2016 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION TRANSIENT IMMUNITY OUTPUT EN INPUT ADDING HYSTERESIS DEVICE OPTIONS OUTLINE DIMENSIONS ORDERING GUIDE
