ADCMP391/ADCMP392/ADCMP393Data Sheet5050ADCMP391ADCMP391ADCMP392ADCMP39245ADCMP39345ADCMP3934040A)A)µ35µ(35(NTNT3030CURRE25CURRE25YYLLPP20PP20SUSU1515101055 14 –50050100 1 17 –50050100 1 TEMPERATURE (°C) 12206- TEMPERATURE (°C) 12206- Figure 14. Supply Current vs. Temperature at Output High Voltage Figure 17. Supply Current vs. Temperature at Output Low Voltage for Various Supply Voltages (VCC) for Various Supply Voltages (VCC) 3.83.9VCC = 2.3V3.6VCC = 3.3V3.7VCC = 5.5V3.53.4V)V)3.33.2S (mS (m3.1ESI3.0ESI2.9ERER2.82.7YSTYSTHHTT2.52.6PUPUIN2.3IN2.4T2.1A = +25°CTA = +85°C2.21.9TA = +125°C TA = –40°C2.01.7 15 18 –50–250255075100125 1 2.32.73.13.53.94.34.75.15.5 1 TEMPERATURE (°C) 12206- SUPPLY VOLTAGE (V) 12206- Figure 15. Input Hysteresis vs. Temperature for Figure 18. Input Hysteresis vs. Supply Voltage (VCC) for Various Supply Voltages (VCC), VCM = 1 V Various Temperatures, VCM = 1 V 814VCC = 2.3VRPULLUP = 10kΩVCC = 2.3VRPULLUP = 10kΩVCC = 3.3VVOD = 10mVVCC = 3.3VVOD = 10mVVC12VC7CC = 5.5VL = 50pFCC = 5.5VL = 50pFVCM = 1VVCM = 1Vs)s)µµ(10(6AYAYLL8N DE5N DEIOIOAT6ATAGAGP4PRO4ROPP3220 16 19 –50–250255075100125 1 –50–250255075100125 1 TEMPERATURE (°C) 12206- TEMPERATURE (°C) 12206- Figure 16. Propagation Delay vs. Temperature, Low to High, VOD = 10 mV Figure 19. Propagation Delay vs. Temperature, High to Low, VOD = 10 mV Rev. D | Page 8 of 17 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAMS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION BASIC COMPARATOR RAIL-TO-RAIL INPUT (RRI) OPEN-DRAIN OUTPUT POWER-UP BEHAVIOR CROSSOVER BIAS POINT COMPARATOR HYSTERESIS TYPICAL APPLICATIONS ADDING HYSTERESIS WINDOW COMPARATOR FOR POSITIVE VOLTAGE MONITORING WINDOW COMPARATOR FOR NEGATIVE VOLTAGE MONITORING PROGRAMMABLE SEQUENCING CONTROL CIRCUIT MIRRORED VOLTAGE SEQUENCER EXAMPLE THRESHOLD AND TIMEOUT PROGRAMMABLE VOLTAGE SUPERVISOR OUTLINE DIMENSIONS ORDERING GUIDE
