Datasheet ADCMP671 (Analog Devices) - 5
Description | Low Power Adjustable UV and OV Monitor with 400 mV 0.275% Reference |
Pages / Page | 16 / 5 — Data Sheet. ADCMP671. Table 3. Parameter Min. Typ. Max. Unit. Test. … |
File Format / Size | PDF / 313 Kb |
Data Sheet. ADCMP671. Table 3. Parameter Min. Typ. Max. Unit. Test. Conditions/Comments
link to page 5 link to page 5 link to page 5 link to page 5
Data Sheet ADCMP671
VDD = 1.7 V to 5.5 V, −40°C ≤ TA ≤ +85°C, unless otherwise noted.
Table 3. Parameter Min Typ Max Unit Test Conditions/Comments
THRESHOLDS1 Rising Input Threshold Voltage (VTH(R)) 391.2 407.8 mV VDD = 1.7 V 393.1 405.9 mV VDD = 3.3 V 393.5 405.4 mV VDD = 5.5 V Falling Input Threshold Voltage (VTH(F)) 383.3 400.9 mV VDD = 1.7 V 384.7 398.4 mV VDD = 3.3 V 384.4 398.2 mV VDD = 5.5 V Rising Input Threshold Voltage Accuracy ±1.6 % VDD = 3.3 V Falling Input Threshold Voltage Accuracy ±1.75 % VDD = 3.3 V Hysteresis = VTH(R) − VTH(F) 5.4 12.6 mV INPUT CHARACTERISTICS Input Bias Current 1 nA VDD = 1.7 V, VIN = VDD 1 nA VDD = 1.7 V, VIN = 0.1 V OPEN-DRAIN OUTPUTS Output Low Voltage2 250 mV VDD = 1.7 V, IOUT = 3 mA 250 mV VDD = 5.5 V, IOUT = 5 mA Output Leakage Current3 0.1 μA VDD = 1.7 V, VOUT = VDD 0.1 μA VDD = 1.7 V, VOUT = 5.5 V POWER SUPPLY Supply Current4 14 μA VDD = 1.7 V 15 μA VDD = 5.5 V 1 RL = 100 kΩ, VOUT = 2 V swing. 2 VIN = 10 mV input overdrive. 3 VIN = 40 mV overdrive. 4 No load. Rev. 0 | Page 5 of 16 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION COMPARATORS AND INTERNAL REFERENCE POWER SUPPLY INPUTS HYSTERESIS VOLTAGE MONITORING SCHEME OUTPUTS OUTLINE DIMENSIONS ORDERING GUIDE
