Datasheet ADCMP670 (Analog Devices) - 5
Description | Dual Low Power 1.5% Comparator With 400 mV Reference |
Pages / Page | 16 / 5 — ADCMP670. Table 4. Parameter Min. Typ. Max. Unit. Test. … |
Revision | A |
File Format / Size | PDF / 337 Kb |
ADCMP670. Table 4. Parameter Min. Typ. Max. Unit. Test. Conditions/Comments
link to page 16 link to page 16 link to page 16 link to page 16
ADCMP670
VDD = 1.7 V to 5.5 V, −40°C ≤ TA ≤ 125°C, unless otherwise noted.
Table 4. Parameter Min Typ Max Unit Test Conditions/Comments
THRESHOLDS1 Rising Input Threshold Voltage 390 411 mV VDD = 1.7 V 392 410 mV VDD = 5.5 V Falling Input Threshold Voltage 381.5 405.5 mV VDD = 1.7 V 381.05 404.5 mV VDD = 5.5 V Hysteresis = VTH(R) – VTH(F) 2 13.5 mV INPUT CHARACTERISTICS Input Bias Current 45 nA VDD = 1.7 V, VIN = VDD 45 nA VDD = 1.7 V, VIN = 0.1 V OPEN-DRAIN OUTPUTS Output Low Voltage2 250 mV VDD = 1.7 V, IOUT = 3 mA 250 mV VDD = 5.5 V, IOUT = 5 mA Output Leakage Current3 1 μA VDD = 1.7 V, VOUT = VDD 1 μA VDD = 1.7 V, VOUT = 5.5 V POWER SUPPLY Supply Current4 16 μA VDD = 1.7 V 17 μA VDD= 5.5 V 1 RL = 100 kΩ, VO = 2 V swing. 2 10 mV input overdrive. 3 VIN = 40 mV overdrive. 4 No load. Rev. A | Page 5 of 16 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS APPLICATION INFORMATION COMPARATORS AND INTERNAL REFERENCE POWER SUPPLY INPUTS OUTPUTS ADDING HYSTERESIS OUTLINE DIMENSIONS ORDERING GUIDE
