Datasheet ADCMP670 (Analog Devices) - 9
Description | Dual Low Power 1.5% Comparator With 400 mV Reference |
Pages / Page | 16 / 9 — ADCMP670. 12.0. 11.5. VDD = 1.8V. 11.0. DD = 2.5V. 10.5. DD = 3.3V. 10.0. … |
Revision | A |
File Format / Size | PDF / 337 Kb |
ADCMP670. 12.0. 11.5. VDD = 1.8V. 11.0. DD = 2.5V. 10.5. DD = 3.3V. 10.0. DD = 5.0V. 9.5. 9.0. 8.5. FOUR TYPICAL PARTS. 8.0. VDD = 5V. 7.5. 7.0. 6.5. 6.0. 5.5
ADCMP670 12.0 12.0 11.5 1A 11.5 VDD = 1.8V 1B V 11.0 11.0 DD = 2.5V 2A V 10.5 10.5 DD = 3.3V 2B V 10.0 10.0 DD = 5.0V 9.5 9.5 V) V) 9.0 9.0 (m (m IS 8.5 FOUR TYPICAL PARTS IS 8.5 ES 8.0 VDD = 5V ES 8.0 ER 7.5 ER 7.5 ST ST 7.0 7.0 Y Y H H 6.5 6.5 6.0 6.0 5.5 5.5 5.0 5.0 4.5 4.5 4.0 4.0 –40 –20 0 20 40 60 80 100 120
10 13 0
0 3- 3-
TEMPERATURE (°C)
49
TEMPERATURE (°C)
49 06 06 Figure 10. Hysteresis vs. Temperature Figure 13. Hysteresis vs. Temperature
12 1 TA = +125°C 11 0 10 V) T m TA = –40°C V) A = +25°C ( –1 9 T TA = +25°C (m IF T IS A = +85°C TA = +85°C SH T ES 8 D A = +125°C –2 R L E O ST 7 Y H T ESH A = –40°C R –3 H 6 T –4 5 4 –5 1.7 2.2 2.7 3.2 3.7 4.2 4.7 5.2 5.7
1
1.5 1.6 1.7 1.8 1.9 2.0 2.1 2.2 2.3 2.4 2.5
4 01 01 3- 3-
SUPPLY VOLTAGE (V)
49
SUPPLY VOLTAGE (V)
49 06 06 Figure 11. Hysteresis vs. Supply Voltage Figure 14. Minimum Supply Voltage
10 50 NO LOAD CURRENT 9 40 A) A) µ µ ( 8 ( NT TA = +125°C T NT 30 A = +85°C 7 CURRE CURRE Y Y L T L 20 P A = +25°C P 6 UP UP S S T T A = –40°C A = +25°C 10 5 TA = +85°C TA = +125°C TA = –40°C 4 0 1.7 2.2 2.7 3.2 3.7 4.2 4.7 5.2
2 15 01
0 0.5 1.0 1.5
0 3- 3-
SUPPLY VOLTAGE (V)
49
SUPPLY VOLTAGE (V)
49 06 06 Figure 12. Quiescent Supply Current vs. Supply Voltage Figure 15. Startup Supply Current Rev. A | Page 9 of 16 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS APPLICATION INFORMATION COMPARATORS AND INTERNAL REFERENCE POWER SUPPLY INPUTS OUTPUTS ADDING HYSTERESIS OUTLINE DIMENSIONS ORDERING GUIDE
