Datasheet ADCMP361 (Analog Devices) - 8
DescriptionSingle 0.275% Comparator and Reference with Dual Polarity Outputs
Pages / Page12 / 8 — ADCMP361. Data Sheet. 1000. 10k. A = 85°C. DD = 5.0V. CURRENT IS GOING. …
File Format / SizePDF / 296 Kb
ADCMP361. Data Sheet. 1000. 10k. A = 85°C. DD = 5.0V. CURRENT IS GOING. OUT OF THE DEVICE. DD = 3.3V. A = +125°C. DD = 2.5V. DD = 5V
ADCMP361 Data Sheet 1000 10k A = 85°C DD = 5.0V CURRENT IS GOING OUT OF THE DEVICE DD = 3.3V A = +125°C DD = 2.5V DD = 5V
ADCMP361 Data Sheet 1000 10k T V A = 85°C DD = 5.0V CURRENT IS GOING V T OUT OF THE DEVICE. DD = 3.3V A = +125°C V V DD = 2.5V DD = 5V V –0.3V < VIB < 0V DD = 1.7V 1k A) A) n µ ( ( 100 NT NT 100 CURRE T CURRE A = +85°C T Y AS A = +25°C L 10 P BI 10 UP UT S INP 1 TA = –40°C 1 0.1 0.001 0.01 0.1 1 10 100
015
–0.3 –0.2 –0.1 0
016
OUTPUT SINK CURRENT (mA) INPUT VOLTAGE (V)
06496- 06496- Figure 17. Supply Current vs. Output Sink Current Figure 20. Below Ground Input Bias Current
3 10 1 A) A) TA = +125°C n n ( ( T 1 NT A = +125°C NT –1 TA = +85°C TA = +25°C TA = +85°C T CURRE A = –40°C CURRE AS –3 AS BI BI TA = +25°C TA = –40°C 0.1 UT UT INP INP –5 CURRENT IS POSITIVE GOING INTO THE DEVICE. CURRENT IS GOING INTO THE DEVICE V V DD = 5V DD = 5V 0V < V V IB < 1V IB > 1V –7 0.01 0 0.2 0.4 0.6 0.8 1.0
017
1 2 3 4 5
018
INPUT VOLTAGE (V) INPUT VOLTAGE (V)
06496- 06496- Figure 18. Low Level Input Bias Current Figure 21. High Level Input Bias Current
1000 1000 T T A = 25°C A = –40°C ) ) VDD = 5.0V V VDD = 5.0V V V m V m DD = 3.3V ( DD = 3.3V ( V V DD = 2.5V DD = 2.5V GE V V GE DD = 1.8V DD = 1.8V 100 100 OLTA OLTA V V TION TION A A R R TU TU A 10 A 10 T S T S U U TP TP OU OU 1 1 0.001 0.01 0.1 1 10
019
0.001 0.01 0.1 1 10
020
OUTPUT SINK CURRENT (mA) OUTPUT SINK CURRENT (mA)
06496- 06496- Figure 19. Output Saturation Voltage vs. Output Sink Current Figure 22. Output Saturation Voltage vs. Output Sink Current Rev. B | Page 8 of 12 Document Outline Features Applications Functional Block Diagram General Description Table of Contents Revision History Specifications Absolute Maximum Ratings Thermal Characteristics ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Application Information Comparators and Internal Reference Power Supply Inputs Outputs Adding Hysteresis Outline Dimensions Ordering Guide Automative Products
