Datasheet ADCMP341, ADCMP343 (Analog Devices) - 5
DescriptionDual 0.275% Comparator and Reference with Programmable Hysteresis
Pages / Page12 / 5 — Data Sheet. ADCMP341/ADCMP343. PIN CONFIGURATIONS AND FUNCTION …
RevisionA
File Format / SizePDF / 347 Kb
Data Sheet. ADCMP341/ADCMP343. PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS. OUTA. OUTB. +INA_U. ADCMP341. –INA_U. ADCMP343. TOP VIEW
Data Sheet ADCMP341/ADCMP343 PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS OUTA OUTB +INA_U ADCMP341 –INA_U ADCMP343 TOP VIEW
Data Sheet ADCMP341/ADCMP343 PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS OUTA 1 8 OUTB OUTA 1 8 OUTB +INA_U 2 7 V ADCMP341 DD –INA_U 2 7 V ADCMP343 DD TOP VIEW TOP VIEW +INA_L 3 (Not to Scale) 6 +INB_U –INA_L 3 (Not to Scale) 6 –INB_U
003 004
GND 4 5 +INB_L GND 4 5 –INB_L
06500- 06500- Figure 4. ADCMP341 Pin Configuration Figure 5. ADCMP343 Pin Configuration
Table 4. Pin Function Descriptions Pin No. Mnemonic Description
1 OUTA Open-Drain Output for Comparator A. 2 ±INA_U Monitors Analog Input Voltage on Comparator A. Connect to the upper tap point of the resistor string. Connect internally to the noninverting input on the ADCMP341 or the inverting pin on the ADCMP343 via a mux controlled by the output level on Comparator A. The other input of Comparator A is connected to a 400 mV reference. 3 ±INA_L Monitors Analog Input Voltage on Comparator A. Connect to the lower tap point of the resistor string. Connect internally to the noninverting input on the ADCMP341 or the inverting pin on the ADCMP343 via a mux controlled by the output level on Comparator A. The other input of Comparator A is connected to a 400 mV reference. 4 GND Ground. 5 ±INB_L Monitors Analog Input Voltage on Comparator B. Connect to the lower tap point of the resistor string. Connect internally to the noninverting input on the ADCMP341 or the inverting pin on the ADCMP343 via a mux controlled by the output level on Comparator B. The other input of Comparator B is connected to a 400 mV reference. 6 ±INB_U Monitors Analog Input Voltage on Comparator B. Connect to the upper tap point of the resistor string. Connect internally to the noninverting input on the ADCMP341 or the inverting pin on the ADCMP343 via a mux controlled by the output level on Comparator B. The other input of Comparator B is connected to a 400 mV reference. 7 VDD Power Supply Pin. 8 OUTB Open-Drain Output for Comparator B. Rev. A | Page 5 of 12 Document Outline Features Applications General Description Functional Block Diagrams Revision History Specifications Absolute Maximum Ratings Thermal Characteristics ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Application Information Comparators and Internal Reference Power Supply Inputs Outputs Programming Hysteresis Layout Recommendations Outline Dimensions Ordering Guide
