Datasheet ADCMP606, ADCMP607 (Analog Devices) - 4
DescriptionRail-to-Rail, Very Fast, 2.5 V to 5.5 V, Single-Supply CML Comparator in a 12-lead LSCFP Package
Pages / Page14 / 4 — ADCMP606/ADCMP607. Data Sheet. Parameter. Symbol. Test …
RevisionC
File Format / SizePDF / 375 Kb
ADCMP606/ADCMP607. Data Sheet. Parameter. Symbol. Test Conditions/Comments Min. Typ. Max. Unit
ADCMP606/ADCMP607 Data Sheet Parameter Symbol Test Conditions/Comments Min Typ Max Unit
AC PERFORMANCE1 Rise Time/Fall time tR/tF 10% to 90%, 160 ps VCCI = VCCO = 2.5 V to 5.5 V Propagation Delay tPD VCCI = VCCO = 2.5 V to 5.5 V, 1.2 ns VOD = 50 mV VCCI = VCCO = 2.5 V, 2.1 ns VOD = 10 mV Propagation Delay Skew—Rising to TPINSKEW VOD = 50 mV 40 ps Falling Transition Overdrive Dispersion 10 mV < VOD < 125 mV 2.3 ns Common-Mode Dispersion −0.2 V < VCM < VCC + 0.2 V 150 ps Input Stage Bandwidth 750 MHz RMS Random Jitter RJ VOD = 200 mV, 0.5 V/ns 2 ps Minimum Pulse Width PWMIN VCCI = VCCO = 5.5 V, 1.1 ns PWOUT = 90% of PWIN Output Skew Q to Q TDIFFSKEW 50% 20 ps POWER SUPPLY Input Supply Voltage Range VCCI 2.5 5.5 V Output Supply Voltage Range VCCO 2.5 5.5 V Positive Supply Differential (ADCMP607) VCCI − VCCO Operating −3.0 +3.0 V VCCI − VCCO Nonoperating −6 +6 V Positive Supply Current (ADCMP606) IVCCI/VCCO VCCI = VCCO = 2.5 V 11 17.5 21 mA VCCI = VCCO = 5.5 V 16 20.5 26 mA Input Section Supply Current (ADCMP607) IVCCI VCCI = 2.5 V 0.5 1.1 1.5 mA Output Section Supply Current (ADCMP607) IVCCO VCCO = 2.5 V 10 15.8 18 mA IVCCO VCCO= 5.5 V 16 18 25 mA Power Dissipation PD VCCI = VCCO = 2.5 V 30 46 55 mW PD VCCI = VCCO = 5.5 V 90 110 150 mW Power Supply Rejection Ratio PSRR VCCI = 2.5 V to 5 V −50 dB Shutdown Mode ICCI VCCI = VCCO = 2.5 V to 5 V 200 240 800 µA Shutdown Mode ICCO VCCI = VCCO = 2.5 V to 5 V −30 30 µA 1 VIN = 100 mV square input at 50 MHz, VCM = 2.5 V, VCCI = VCCO = 2.5 V, unless otherwise noted. Rev. C | Page 4 of 14 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS TIMING INFORMATION ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION POWER/GROUND LAYOUT AND BYPASSING CML-COMPATIBLE OUTPUT STAGE USING/DISABLING THE LATCH FEATURE OPTIMIZING PERFORMANCE COMPARATOR PROPAGATION DELAY DISPERSION COMPARATOR HYSTERESIS CROSSOVER BIAS POINTS MINIMUM INPUT SLEW RATE REQUIREMENT TYPICAL APPLICATION CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE
