Datasheet ADCMP606, ADCMP607 (Analog Devices) - 5
DescriptionRail-to-Rail, Very Fast, 2.5 V to 5.5 V, Single-Supply CML Comparator in a 12-lead LSCFP Package
Pages / Page14 / 5 — Data Sheet. ADCMP606/ADCMP607. TIMING INFORMATION. 1.1V. LATCH ENABLE. …
RevisionC
File Format / SizePDF / 375 Kb
Data Sheet. ADCMP606/ADCMP607. TIMING INFORMATION. 1.1V. LATCH ENABLE. tPL. DIFFERENTIAL. VIN. VN ± VOS. INPUT VOLTAGE. VOD. tPDL. tPLOH
Data Sheet ADCMP606/ADCMP607 TIMING INFORMATION 1.1V LATCH ENABLE tPL DIFFERENTIAL VIN VN ± VOS INPUT VOLTAGE VOD tPDL tPLOH
link to page 5 link to page 5 link to page 5
Figure 2 il ustrates the ADCMP606/ADCMP607 latch timing relationships. Table 2 provides definitions of the terms shown in Figure 2.
1.1V LATCH ENABLE tS tPL tH DIFFERENTIAL VIN VN ± VOS INPUT VOLTAGE VOD tPDL tPLOH Q OUTPUT 50% tF tPDH 50% Q OUTPUT tPLOL
025
tR
05917- Figure 2. System Timing Diagram
Table 2. Timing Descriptions Symbol Symbol Description Timing Description
tF Output fall time Amount of time required to transition from a high to a low output as measured at the 20% and 80% points. tH Minimum hold time Minimum time after the negative transition of the latch enable signal that the input signal must remain unchanged to be acquired and held at the outputs. tPDH Input to output high delay Propagation delay measured from the time the input signal crosses the reference (± the input offset voltage) to the 50% point of an output low-to-high transition. tPDL Input to output low delay Propagation delay measured from the time the input signal crosses the reference (± the input offset voltage) to the 50% point of an output high-to-low transition. tPL Minimum latch enable pulse width Minimum time that the latch enable signal must be high to acquire an input signal change. tPLOH Latch enable to output high delay Propagation delay measured from the 50% point of the latch enable signal low-to-high transition to the 50% point of an output low-to-high transition. tPLOL Latch enable to output low delay Propagation delay measured from the 50% point of the latch enable signal low-to-high transition to the 50% point of an output high-to-low transition. tR Output rise time Amount of time required to transition from a low to a high output as measured at the 20% and 80% points. tS Minimum setup time Minimum time before the negative transition of the latch enable signal occurs that an input signal change must be present to be acquired and held at the outputs. VOD Voltage overdrive Difference between the input voltages VA and VB. Rev. C | Page 5 of 14 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS TIMING INFORMATION ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION POWER/GROUND LAYOUT AND BYPASSING CML-COMPATIBLE OUTPUT STAGE USING/DISABLING THE LATCH FEATURE OPTIMIZING PERFORMANCE COMPARATOR PROPAGATION DELAY DISPERSION COMPARATOR HYSTERESIS CROSSOVER BIAS POINTS MINIMUM INPUT SLEW RATE REQUIREMENT TYPICAL APPLICATION CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE
