Datasheet ADCMP606, ADCMP607 (Analog Devices) - 8
DescriptionRail-to-Rail, Very Fast, 2.5 V to 5.5 V, Single-Supply CML Comparator in a 12-lead LSCFP Package
Pages / Page14 / 8 — ADCMP606/ADCMP607. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 800. …
RevisionC
File Format / SizePDF / 375 Kb
ADCMP606/ADCMP607. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 800. 250. 600. 200. 400. CC = 2.5V. CC = 5.5V. 150. S (m. ESI ER. –40°C. 100
ADCMP606/ADCMP607 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS 800 250 600 200 400 CC = 2.5V CC = 5.5V 150 S (m ESI ER –40°C 100
VCCI = VCCO = 2.5 V, TA = 25°C, unless otherwise noted.
800 250 600 200 400 V V CC = 2.5V CC = 5.5V V) A) 200 µ 150 ( S (m NT 0 ESI ER –40°C 100 CURRE –200 YST +25°C H –400 50 –600 +125°C –800 0 –1 0 1 2 3 4 5 6 7
026
0 –2 –4 –6 –8 –10 –12 –14 –16 –18
004
LE/HYS PIN (V) LE/HYS PIN CURRENT (µA)
05917- 05917- Figure 5. LE/HYS Pin Current vs. Voltage Figure 8. Hysteresis vs. LE/HYS Pin Current
200 400 150 350 300 100 V V V) A) CC = 2.5V CC = 5.5V 250 µ ( 50 S (m NT ESI 200 0 ER CURRE 150 YST H –50 V 100 CC = 2.5V –100 50 –150 0 –1 0 1 2 3 4 5 6 7
007
50 100 150 200 250 300 350 400 450 500 550 600 650
005
SDN PIN (V) HYS RESISTOR (kΩ)
05917- 05917- Figure 6. SDN Pin Current vs. Voltage Figure 9. Hysteresis vs. Hysteresis Resistor
10 3.5 8 6 3.0 s) n 4 ( AY 2 L 2.5 A) µ 0 N DE ( IO I B –2 AT 2.0 AG P –4 –40°C RO P PROPAGATION DELAY FALL –6 1.5 +25°C –8 +125°C PROPAGATION DELAY RISE –10 1.0 –1.0 –0.5 0 0.5 1.0 1.5 2.0 2.5 3.0 3.5
006
0 10 20 30 40 50 60 70 80 90 100 110 120 130 140
009
VCM AT VCC = 2.5V OVERDRIVE (mV)
05917- 05917- Figure 7. Input Bias Current vs. Input Common-Mode Voltage Figure 10. Propagation Delay vs. Input Overdrive Rev. C | Page 8 of 14 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS TIMING INFORMATION ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION POWER/GROUND LAYOUT AND BYPASSING CML-COMPATIBLE OUTPUT STAGE USING/DISABLING THE LATCH FEATURE OPTIMIZING PERFORMANCE COMPARATOR PROPAGATION DELAY DISPERSION COMPARATOR HYSTERESIS CROSSOVER BIAS POINTS MINIMUM INPUT SLEW RATE REQUIREMENT TYPICAL APPLICATION CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE
