Datasheet ADCMP606, ADCMP607 (Analog Devices) - 9
DescriptionRail-to-Rail, Very Fast, 2.5 V to 5.5 V, Single-Supply CML Comparator in a 12-lead LSCFP Package
Pages / Page14 / 9 — Data Sheet. ADCMP606/ADCMP607. 1.4. PROPAGATION DELAY FALL ns. 5.550V. s) …
RevisionC
File Format / SizePDF / 375 Kb
Data Sheet. ADCMP606/ADCMP607. 1.4. PROPAGATION DELAY FALL ns. 5.550V. s) n ( Y 1.3. A L E. N D IO T A. AG P 1.2. O R P
Data Sheet ADCMP606/ADCMP607 1.4 PROPAGATION DELAY FALL ns 5.550V s) n ( Y 1.3 A L E N D IO T A AG P 1.2 O R P
Data Sheet ADCMP606/ADCMP607 1.4 PROPAGATION DELAY FALL ns 5.550V Q s) n ( Y 1.3 A L E N D IO T A AG P 1.2 O R P PROPAGATION DELAY RISE ns Q
2 01
1.1
10 7-
–0.2 0.2 0.6 1.0 1.4 1.8 2.2 2.6 3.0
0
5.050V 2.000ns/DIV
7- 591 0
V
91
CM AT VCC = 2.5V
05 Figure 11. Propagation Delay vs. Input Common-Mode Voltage Figure 13. Output Waveform at VCC = 5.5 V
2.550V Q Q
1 -01
2.050V 2.000ns/DIV
917 5 0 Figure 12 .Output Waveform at VCC = 2.5 V Rev. C | Page 9 of 14 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS TIMING INFORMATION ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION POWER/GROUND LAYOUT AND BYPASSING CML-COMPATIBLE OUTPUT STAGE USING/DISABLING THE LATCH FEATURE OPTIMIZING PERFORMANCE COMPARATOR PROPAGATION DELAY DISPERSION COMPARATOR HYSTERESIS CROSSOVER BIAS POINTS MINIMUM INPUT SLEW RATE REQUIREMENT TYPICAL APPLICATION CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE
