Datasheet ADCMP603 (Analog Devices) - 3
DescriptionRail-to-Rail, Very Fast, 2.5 V to 5.5 V, Single-Supply TTL/CMOS Comparator
Pages / Page16 / 3 — Data Sheet. ADCMP603. SPECIFICATIONS ELECTRICAL CHARACTERISTICS. Table 1. …
File Format / SizePDF / 321 Kb
Data Sheet. ADCMP603. SPECIFICATIONS ELECTRICAL CHARACTERISTICS. Table 1. Parameter. Symbol. Test Conditions/Comments Min. Typ. Max
Data Sheet ADCMP603 SPECIFICATIONS ELECTRICAL CHARACTERISTICS Table 1 Parameter Symbol Test Conditions/Comments Min Typ Max
VCCI = VCCO = 2.5 V, TA = 25°C, unless otherwise noted.
Table 1. Parameter Symbol Test Conditions/Comments Min Typ Max Unit
DC INPUT CHARACTERISTICS Voltage Range VP, VN VCC = 2.5 V to 5.5 V −0.5 VCC + 0.2 V Common-Mode Range VCC = 2.5 V to 5.5 V −0.2 VCC + 0.2 V Differential Voltage VCC = 2.5 V to 5.5 V VCC + 0.8 V Offset Voltage VOS −5.0 ±2 +5.0 mV Bias Current IP, IN −5.0 ±2 +5.0 µA Offset Current −2.0 2.0 µA Capacitance CP, CN 1.0 pF Resistance, Differential Mode −0.5 V to VCC + 0.2 V 200 700 kΩ Resistance, Common Mode −0.2 V to VCC + 0.2 V 100 350 kΩ Active Gain AV 85 dB Common-Mode Rejection Ratio CMRR VCCI = 2.5 V, VCCO = 2.5 V, 50 dB VCM = −0.2 V to +2.7 V VCCI = 5.5 V, VCCO = 5.5 V, 50 dB VCM = −0.2 V to +5.7 V Hysteresis RHYS = ∞ 0.1 mV LATCH ENABLE PIN CHARACTERISTICS VIH Hysteresis is shut off 2.0 VCC V VIL Latch mode guaranteed −0.2 +0.4 +0.8 V IIH VIH = VCC −6 +6 µA IOL VIL = 0.4 V −0.1 mA HYSTERESIS MODE AND TIMING Hysteresis Mode Bias Voltage Current sink −1 μA 1.145 1.25 1.35 V Resistor Value Hysteresis = 120 mV 65 80 95 kΩ Hysteresis Current Hysteresis = 120 mV −18 −14 −10 µA Latch Setup Time tS VOD = 50 mV −2.0 ns Latch Hold Time tH VOD = 50 mV 2.0 ns Latch-to-Output Delay tPLOH, tPLOL VOD = 50 mV 30 ns Latch Minimum Pulse Width tPL VOD = 50 mV 23 ns SHUTDOWN PIN CHARACTERISTICS VIH Comparator is operating 2.0 VCCO V VIL Shutdown guaranteed −0.2 +0.4 +0.6 V IIH VIH = VCC −6 +6 µA IOL VIL = 0 V −80 µA Sleep Time tSD IOUT < 0.5 mA 20 ns Wake-Up Time tH VOD = 100 mV, output valid 50 ns DC OUTPUT CHARACTERISTICS VCCO = 2.5 V to 5.5 V Output Voltage High Level VOH IOH = 8 mA VCCO = 2.5 V VCC − 0.4 V Output Voltage High Level −40°C VOH IOH = 6 mA VCCO = 2.5 V VCC − 0.4 V Output Voltage Low Level VOL IOL = 8 mA, VCCO = 2.5 V 0.4 V Output Voltage Low Level −40°C VOL IOL = 6 mA, VCCO = 2.5 V 0.4 V Rev. A | Page 3 of 16 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS TIMING INFORMATION ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION POWER/GROUND LAYOUT AND BYPASSING TTL-/CMOS-COMPATIBLE OUTPUT STAGE USING/DISABLING THE LATCH FEATURE OPTIMIZING PERFORMANCE COMPARATOR PROPAGATION DELAY DISPERSION COMPARATOR HYSTERESIS CROSSOVER BIAS POINT MINIMUM INPUT SLEW RATE REQUIREMENT TYPICAL APPLICATION CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE
